Old 07-22-2010, 09:41 PM
spiess21 spiess21 is offline
Default Digi 002 Problems with PT LE 8.0.4
Just installed the update for 8.0.4. Everything was working fine with 8.0.1 and 8.0.3 until I updated to .4. Now I cannot get the 002 to record any type of track. It does not seem to be reading any audio or midi track which is enabled and record ready. It will play back previously recorded sessions but nothing new can be recorded. Checked the I/O settings and the paths seem to be correct. Can this be a Vista Ultimate problem? Already unistalled and reinstalled it one 2 times.
Any suggestions?
Thanks
Old 07-22-2010, 10:04 PM
DarylBham DarylBham is offline
Default Re: Digi 002 Problems with PT LE 8.0.4
I think we have a similar issue... try to bus out to busses 1 and 2, make an auxilary bus track to receive them, and then see if you can hear or record anything
My original post was this: http://duc.digidesign.com/showthread.php?t=278273
Old 07-22-2010, 11:57 PM
sw rec sw rec is offline
8.0.4 wasn't intended for Vista. That's a Win 7 version.
Old 07-23-2010, 12:09 AM
oh, you are right SW... my bad
Old 07-23-2010, 12:32 AM
mykhal c's Avatar
mykhal c mykhal c is offline
8.0.4 is for XP and Vista (32 bit) and W7 (32 and 64 bit). it is the last version for XP and Vista for LE/MP. XP for HD will live at least another version.
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 07-23-2010, 12:51 AM
nerhal nerhal is offline
you might want to double check your routing options. or I/O
AMD Phenom(tm) II X4 955 Processor 3.21GHz
Gigabyte GA-790XTA-UD4
Total Memory : 4GB DIMM DDR3
Memory Bus Speed : 2x 670MHz (1.34GHz)
western digital black (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (C:)
western digital black (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (D:)
Memorex DVD+-RAM 550L v1 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:)
Windows 7 Ultimate 6.01.7600 x64
gateway 24inch hdmi dvi HD monitor
pro tools LE 8.0.4
Old 07-23-2010, 01:08 AM
i have defaulted mine, so i know thats not my issue, i even reverted back to 8.03 the other day, everything was fine... tried it again all day today, same issues... i think im going to revert back again once i buy this Acronis thing tomorrow
Old 07-23-2010, 01:15 AM
mykhal c's Avatar
i believe prefs get reset when goin' to 8.0.4. make sure that your hdds/partitions are record ready in the workspace...since you say it's a record issue and not playback.
Old 07-23-2010, 01:31 AM
if you are talking to me, sorry, mine is a record and playback issue.... preferences were dumped, everything was setup and resetup... my issue has to be somethin with the drivers(i think)
Old 07-23-2010, 02:07 AM
mykhal c's Avatar
my bad...thought you were the OP
Digi 002 and PT9 problems Phox Pro Tools 9 3 11-21-2010 06:49 PM
Digi 002 Problems with new 7.0 riotbeats 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-30-2006 06:47 AM
Is there a PC for Digi 002 that WON'T have problems?? SJSJR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-08-2003 11:15 AM
PC Probe problems. Any overheatingg problems with Digi 001 Ajay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-03-2002 05:30 PM
Digi 001/PT LE G4 500 Problems! byteme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-15-2000 03:50 PM
