Old 03-26-2006, 08:26 PM
sflood75 sflood75 is offline
Default Mide-Side Recording
Working on PT7.0 TDM system. Doing some field recording in MS Stereo with Senn 418. Looking to hear if I can decode into PT? Any suggetions?
Old 03-26-2006, 08:44 PM
Improv Improv is offline
Default Re: Mide-Side Recording
Pan the Mid Channel right up the center, duplicate the Side channel into 2 tracks. Put a trim plugin on all three channels (1 Mid, 2 identical Sides). On the duplicate Side channel, flip the phase on the trim plugin. Pan that channel Left. Pan the original Side channel Right.
Or use Waves MS encoder/decoder or something similar.
Old 03-27-2006, 03:28 AM
Stig Eliassen's Avatar
__________________________________________________ _________________________________________________
"Welcome to the Digidesign User Conference — The DUC
Please post your message (once only) to the correct forum from the Main Index"
Old 03-27-2006, 05:03 PM
TimNielsen TimNielsen is offline
I think you want the non-phase flipped side channel pointing the left channel, and the phase-flipped one panned right.
Old 03-27-2006, 05:31 PM
Andre Knecht Andre Knecht is offline
Gently click on this here underlined sentence.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 03-28-2006, 12:51 PM
Ducky Ducky is offline
Proper mid-side signal routing can be found in THIS document.
Digi,Side by Side errors in event viewer with PT's HD 7.4? x9blade Pro Tools TDM Systems (Win) 8 12-15-2007 11:19 AM
Change mide note height - how to ? dkrz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-09-2007 03:35 PM
Decoding a Mid-Side recording sflood75 Tips & Tricks 3 04-28-2006 08:51 AM
BUSINESS 101 side of recording....adviced needed!! storm-01 Pro Tools TDM Systems (Mac) 8 10-21-2003 09:56 PM
BUSINESS 101 side of recording....adviced needed!! storm-01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-21-2003 09:37 PM
