Old 01-05-2006, 04:11 PM
bruce_pianoman bruce_pianoman is offline
Default edit->cut fails (doesn\'t cut)
I have a pro tools LE 6.7 session with several stereo tracks that I've recorded. I am trying to "cut" or otherwise delete a short section at the end of one of the tracks. I select the section by dragging the mouse across it. It turns dark as I expect it to. But when I click on Edit->Cut, the section is still there. I even selected the entire track by clicking on it in the right place and I can't "cut" that, either.
I've successfully cut before, but I can't figure out what's different this time. I'm a novice user & a light-weight user.
I looked up cut in both the menu guide and the reference guide, but didn't find any clues there. I really appreciate any help!
Thanks,
Bruce
My computer setup: powermac g5, 160gb hard drive (I need to get another drive), OS 10.3.9
Old 01-05-2006, 04:39 PM
Default Re: edit->cut fails (doesn\'t cut)
Okay, I just figured it out myself:
The track was set to "volume" instead of "waveform". I don't know what you call that field, but it's in the info block on the left. I set it to waveform and "cut" worked just fine.
Old 01-05-2006, 05:55 PM
bassntreble bassntreble is offline
It's called the track view selector....hint..read the PDF manual.
G5 1.8X2/3gigRAM/Mbox/7.4 (retired)
MBP C2D 2.4/4GigRAM/Mbox/8.0.1
iMac i7 3.4/16GigRAM/10.0.1
PT 8 Re-Install Fails MarmotMusic macOS 1 10-20-2012 03:19 PM
Upgrade from 9.03 to 9.05 fails jakorsme Pro Tools 9 1 10-16-2011 05:01 PM
PT 7.4.2pr Fails to Launch pk1983 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-16-2008 04:58 AM
Cannot change EDIT MODE in edit window Xavior Pro Tools M-Powered (Mac) 2 05-24-2007 12:51 AM
A display delay when i change Edit\Mix or Mix\Edit jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-27-2002 01:13 AM
