Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 10-18-2005, 02:04 PM
Jonathan Starr Jonathan Starr is offline
Default 10,000 RPM WD Raptor SATA Drives
Has anyone had experience with the Western Digital Raptor 10,000RPM SATA internal drives?
I've been hitting the limit of Firewire throughput, and I'm looking for a single internal drive that is fast enough to handle 30 tracks at 96k.
The Raptors only come up to 74gigs, so I would use my firewire drives and spare partitions on my large system drive for projects that are not currently in work.
Thanks,
Jonathan Starr
Old 10-18-2005, 06:46 PM
ticktock ticktock is offline
Default Re: 10,000 RPM WD Raptor SATA Drives
Me too.
I saw something around here that said SATA were frowned upon for some compatibility reason. Maybe it was my M-Audio equipment though.
And Pro Tools doesn't support RAIDs.
I guess that leaves SCSI as the only high speed option?
Old 10-19-2005, 12:46 PM
pezguy pezguy is offline
I do not believe the problem lies in the throughput of firewire. I am using two 7200RPM SATA drives and I am able to get the full trackcount of 32 tracks @ 24/96. I would look at bus speed and CPU before looking at the firewire pipe.
Old 11-08-2005, 02:49 PM
To answer my own query; I got one and the Raptor 10,000RPM SATA is fast and works great in my G5 Dual 2.7 for audio files for PTHD.
WD raptor drives with PT mix 6.4.1? musicmixer04 Pro Tools TDM Systems (Mac) 0 06-30-2008 12:39 PM
2 SATA WD Raptor and External Firewire OSX drive ? Dutchmuzik Pro Tools TDM Systems (Mac) 5 05-24-2005 10:21 AM
3 SATA 10K Raptor Drives on the K8V-X mobo? powerjoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-21-2005 02:13 PM
SATA "Raptor" Drives...Interesting stuff Imagine Pro Tools TDM Systems (Mac) 0 06-19-2004 02:52 AM
10K Raptor SATA Drives and PT LE The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-08-2003 10:05 AM
