S3L DA Converter Quality
Is my impression correct? DA converters in S3 and Engine are different in quality then the DA converters in stage 16?
What do you know about? Are the stage 16 converters the same used in the new HD I/O? Patrick
www.tonkultur.ch - remote recording services |
Re: S3L DA Converter Quality
Hi Patrick,
The S3, E3 and Stage 16 all use the same DAC chip from TI. This is not the same DAC as used in HD I/O. Sheldon |
Thanks Sheldon
But why they sound different, honestly I wouldn't use S3 or Engine converters to feed our studio monitoring, they sound not as good as the Stage 16 converters. (I directly routed the signal without any processing (inserts,EQ, Dyn) to the 3 different outputs. A true A-B-C test) I'm glad to test S3L in our recording-mixing location, consider if it works for our needs to get full data exchange between our mobile trailer (venue profile) and the recording studio. We want to be able to record outdoor and finish the product in the studio without starting from zero. Best, Patrick
This type of discussions are always pretty much pointless without audio files. Since I do a bit of work on a S3L system nowadays (as the band's crew refuses to bring the Profile out anymore due to the size and weight difference ) I'm very interested to see if this what Patrick is saying is true. What I plan to do is, to take a snippet of a bands live show recording, bus it out of the Stage16, S3 and Engine outputs into Profile inputs all set to the same level and then share the files with you guys so everyone can listen if there is a difference and best of all, we can try the null test by flipping the phase on one file when A/B'ing two files. It's busy times, but I'll try to make it happen.
Best, Kristo |
96 converter quality | SteveFireland | Pro Tools TDM Systems (Mac) | 10 | 05-21-2010 11:31 PM |
A/D Converter quality - where is the 002R? | davetron5000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-24-2005 04:46 PM |
Converter quality testing...anybody up for it? | Bhennies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 02-25-2005 06:36 PM |
96i i/o converter quality | Papawhitehead | Pro Tools TDM Systems (Mac) | 5 | 10-05-2004 11:23 PM |
96i i/o converter quality | Papawhitehead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-03-2004 05:42 PM |
