Old 05-14-2008, 04:29 AM
priorytools priorytools is offline
Default Digi Clicks ?
Hi. . I'm suddenly getting clicks. . On this project I have added a Rossetta 800 for extra I/O whilst mixing. .
Rig= 3 x 192, 1 x 96i, 1 x 192, then the Rossetta clocked from the sync I/O. . .
192#4 & the Rossetta I'm using for hardware inserts at mix. . 'reason being that I need to keep my tracking set up "live".
So. . What's causing these clicks ?
They aren't in the audio files & are random. . .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 05-14-2008, 12:05 PM
soundonsound soundonsound is offline
Default Re: Digi Clicks ?
Could be a clocking issue. If you use the PT internal clock does the clicking go away? I'd break the setup down a bit and then add additional clocking and interfaces in until the problem comes back. Also trash your digidesgin datbases from all hard drives root level when PT is closed. Check for bad cables that would carry clock.
Any additional info you can post regarding troubleshooting attempted would be helpful.
Old 05-14-2008, 05:00 PM
RobMacki RobMacki is offline
Wordclock?
Digi Mic Pre gain clicks?? Don Geppert ICON & C|24 9 01-09-2007 08:29 PM
odd pops/clicks digimax lt and digi-002 sblair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-07-2005 06:04 PM
PT 6.7 & Digi 192 I/O Clicks SteveH44 Pro Tools TDM Systems (Mac) 0 02-17-2005 12:41 PM
Pops and clicks DIGI 002 rack ---anybody else drumfreak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-15-2005 08:00 AM
Hey DIGI/ 6.1 pops and clicks? lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-05-2003 11:56 PM
