Old 05-13-2008, 06:25 AM
undergroundcubby undergroundcubby is offline
Default Insert Issues - Use Pre I/O or 96 I/O?????
Hi Guys, just setting up my new Pre with 96 I/O, I want to get my Focusrite compressor & Aphex Exciter running as external inserts in my sessions, do I connect into the insert send/returns on the Pre or just patch into the 96 I/O?
Once done I can just open an insert on a channel and pick the channels right?
Thanks
HD 3 Accel PCI
HP XW9300
192 I/O
Midi I/O
Old 05-13-2008, 06:34 AM
RobMacki RobMacki is offline
Default Re: Insert Issues - Use Pre I/O or 96 I/O?????
It depends on if you want to print it or use them as HW inserts.
Old 05-13-2008, 06:40 AM
Hi, Hmmm, I would want to print them but can't I not open an insert on say a virtual instrument channel pick the channel with the compressor etc and then monitor the effect and when happy record it in?
HD 3 Accel PCI
HP XW9300
192 I/O
Midi I/O
Old 05-14-2008, 09:46 AM
Can Anyone else help at all? I am in the middle of cabling it all up now and would love to be able to save some time!
Thanks
HD 3 Accel PCI
HP XW9300
192 I/O
Midi I/O
Old 05-14-2008, 10:54 AM
Craig F Craig F is offline
personally I skip the PRE's inserts and put it's o/ps and the 96 i/ps on the patchbay
Thank you,
Craig
Old 05-14-2008, 11:17 AM
Drew Mazurek's Avatar
Thanks
I believe the PRE's inserts are only for signals plugged into the mic inputs of the unit. They are not I/O usable by PT as hardware inserts. So, use them for tracking with processing while using the PRE, and wire up the 96I/O to use as hardware inserts for mixing.
Hope this helps.
www.drewmazurek.com
Old 05-14-2008, 11:21 AM
Great thanks, so you to confirm, plug the outboard effects into the 96I/O on matching channels for in & out and then in Pro tools I can name them in the I/O window and simply select them as inserts on any channel? (with no latency?)
Thanks guys.
HD 3 Accel PCI
HP XW9300
192 I/O
Midi I/O
Old 05-14-2008, 11:52 AM
Thanks guys.
Correct until the last statement. There is latency (D/A-A/D) but the Delay Comp in PT will compensate, so be sure to have that on.
www.drewmazurek.com
Old 05-14-2008, 02:12 PM
jeff markham's Avatar
jeff markham jeff markham is offline
Thanks guys.
i don't believe PT automatically adjusts the H/W insert delays .. you have to
enter them manually on the Setup->IO->HW Insert dialog.
jeff
Old 05-14-2008, 02:15 PM
Of course it does, that's the whole point of ADC.
When inserting analog gear, PT will compensate for the D/A and A/D, which of course is all the latency there is. If you are inserting digital gear, PT can't know any delays there and that's what those boxes are for.
www.drewmazurek.com
Issues with Hardware Insert I/O's matching Patchpoints on 3 192's NYUTECH Pro Tools 10 2 03-13-2013 01:03 AM
Change one insert on a track - change all tracks with same insert World Spirit macOS 6 02-22-2012 03:07 PM
How to insert hardware as channel insert Lqoau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-19-2012 07:29 AM
How to insert time / insert measures, without upsetting tempo map and markers imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-25-2003 05:45 PM
D-verb Insert won't insert Julien J. Noel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-20-2002 03:37 PM
