Magic mouse
Whenever I use pro tools I get an issue with my magic mouse lagging really badly. I have to keep turning the bluetooth on and off. Anyone else having this experience?
Re: Magic mouse
Stop using a Bluetooth mouse. It's recommended to don't use anything bluetooth at all. Turn it off!
-Mac mini i7 Quad 2.3, 4g ram, OSX 10.10.2, PT11.2.1, iLok 2. -Apogee Quartet, 2 Profire 2626's. |
Re: Magic mouse
Every WL mouse keyboard utilizes BT so turning off is an issue Avid needs to deal with.
(Although I'm not having issues with BT enabled) It's Just not an option for some. I personally like wired but I use a Trackball wired and a Trackpad WL together. I also like the MT and MM and wired versions would have been acceptable as an option primarily due to battery charging. ---- Back to topic. If your mac is blocked the MM or MT can be intermittent. I at one studio like the Magic-trackpad at the console. The mac was in the machine room so I added a Bluetooth-reciever USB device to the keyboard and it works great. PT's 9.0.5, OS 10.7.2, HD3 Magma solution. 12Gb, 12 core Last edited by DetroitT; 10-13-2011 at 03:35 AM. Reason: update |
Re: Magic mouse
If you are using a Mac Pro and you are a bit aways from it, this can be an issue (as it was with mine and my Magic Trackpad, sitting no more than a yard away, with a desk between the two devices). There is a document on the web that details taking the internal BT antenna on the Mac Pro and re-routing it externally. It's a SUPER easy conversion, cheap, and it solved the problem for me - ridiculous BT range, NO dropouts.
Sorry, I don't remember the link, but Google it - it's easy enough to find. It cost me maybe $5ish for the internal cable, then you can spend whatever you like on the external BT antenna - I spent $20 or $25 on mine. |
Re: Magic mouse
Re: Magic mouse
I recommend a USB -> Bluetooth adapter, this fixed it for me.
Oliver |
Re: Magic mouse
Not sure what else to suggest to you. Certainly drilling a port in your MacBook so you can mount an external antenna would be silly. Good luck! |
Re: Magic mouse
Couldn't stand my magic mouse...Laggy, drop outs, crap size....Dumped it for a wired 5 button.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest |
Re: Magic mouse
Doesn't help the OP, though, unfortunately. |
Magic Mouse issues | twix | Pro Tools TDM Systems (Mac) | 14 | 02-14-2010 05:59 PM |
Anybody use a new 'Magic Mouse' yet?? | dougied | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-05-2010 03:41 AM |
Magic Mouse and Protools HD | buckaroo | Pro Tools TDM Systems (Mac) | 3 | 12-29-2009 11:02 AM |
magic mouse | AchimHamburg | Pro Tools TDM Systems (Mac) | 17 | 11-05-2009 06:15 AM |
Apple Magic Mouse | RussUK | General Discussion | 3 | 11-02-2009 06:56 PM |
