#541
Re: Pro Tools placing sound EARLY??
Lenovo T61 T9300 Core 2 Duo 2.5ghz 4GB DDR2 2 1TB FreeAgent Xtreme External Drives SIIG FireWire Express Card Windows 7 Ultimate X64 Pro Tools 8.0.4 LE Digi003 Rack || PreSonus D8 || ART MPA Gold || ART PRO VLA II || Ensoniq DP/2 M-Audio Axiom 49 || Behringer BCF2000 Yamaha HS50Ms Bands: Captain Starr || stereoINs Drums: 1 || 2 || 3 Guitars: 1 || 2 || 3 |
#542
Anyway, I uninstalled the 64-bit drivers that came with the 8.0.4 update and installed the beta drivers. So to clarify I'm using 8.0.4 software with the 64-bit beta drivers and when I run the tests, the pre-latency issue is gone. At all buffer settings, the miked click is about 280 samples behind the click on the first audio track, which I'm guessing is normal. I'm just wondering if anyone can duplicate these results, and is there any reason I shouldn't use this workaround and just go back to 8.0.3??
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
#543
In our tests, using the 8.0.4 beta driver with 8.0.4 was an improvement but not as good a solution as with 8.0.3 with the same beta driver. With the 8.0.4 beta driver and 8.0.4 the material was recorded a little late. With the 8.0.4 beta driver and 8.0.3 the audio is nearly spot on.
#544
#545
Thanks Mike for the re-affirm on 8.0.3cs2 regarding early placement.
Lou
Mac Pro (2019) with 3.5GHz 8-core Intel Xeon W Processor, 48 GB DDR4 Memory, 1TB SSD Catalina 10.15.7 Avid Pro Tools Carbon, Eleven Rack (ERXP 2.0.1), Neve Shelford Channel, SSL Fusion Analog processor, Avid S1 Control Surface, Yamaha Montage 7 (also used as a MIDI controller), Korg Prologue 16 and Adam A7X Monitors. Pro Tools Ultimate 2021.6, Logic Pro, VEP 7, Exponential Audio. Eventide, FabFilter. iZotope, McDSP, MDW, Softube, Sonnox, Soundtoys, Waves. |
#546
Do I need to completely uninstall Pro Tools like it was never there including any digi database folders/files? What about plugins and 3rd party options? When I'm installing 8.0.3 I'm guessing I should NOT connect the Mbox Mini when prompted and then install the 8.0.4 beta drivers afterwards, connecting the Mbox Mini when the driver installation asks for it? Thanks |
#547
I believe so though I don't own an MBox.
#548
Whoa...QuickDraw makes a guest appearance after....? years? Or I'm not on the sections of the forum he is. Whatever, welcome back!
For people on XP I tried a test today with 8.0.4. I only record one voice track at a time so this may or may not be relevant to the issue of early placement, but I'll pass this along anyway: XP SP3 updated as of Sunday October 3, 2010 Athlon 64 X2 processor 2 gb of RAM 002 Rack Approved ADS Pyro FireWire Card Pro Tools LE 8.0.4 Waves Diamond v7r14 Buffer at 1024 Just as a test on the Audio Track (delay 213): H-Delay. Doubler4, PuigTCMEQ5 and L1 Regular Plug-Ins on the Master (delay 128): RenDeEsser, C1 Compressor, TrueVerb and LL-3 Ultra I recorded my mic through my Grace into Analogue 5. There was no early - or late - placement of the audio. Cheers,
#549
Where have you been hiding for the past 6 years or so? Welcome back. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#550
Pro tools placing Samples Early. the opposite of latency. | thecoaster | macOS | 11 | 06-30-2013 02:54 PM |
pro tools is recording early? | Applebase | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-21-2010 07:44 PM |
Early Film Sound Pioneer, George Groves | minister | Post - Surround - Video | 4 | 05-22-2009 01:08 AM |
Early Beatles Sound | AmazingOne | Pro Tools TDM Systems (Mac) | 47 | 02-10-2008 02:49 AM |
film print sound 2 frames early | minister | Post - Surround - Video | 8 | 04-13-2005 09:37 AM |
