Xpand is causing PTF to freeze
Downloaded, installed.
PTF freeze when I open any template. I force quit PTF. Launch PTF. I create a new stereo instrument track. I insert xpand2. PTF freeze. I restart the computer. Still freezing. I'm re-installing PTF right now. Will report back.
iMac 27 inches , late 2012, Quad-core, 8 GB ram, Fusion Drive, 3,4 GHz Intel Core i7, MacOs Mojave 10.14.6, Focusrite Saffire Le, thunderbolt adaptor, 800/400 FW cable. |
Re: Xpand is causing PTF to freeze
Freeze. Logic, Reason, Cubase, Garageband, all work flawlesly. What can I say?
Still no joy.
In the manager is it ok to read "no update" beside xpand II? In the OS X Console I read: 2015-08-22 11:29:18.597 AM Pro Tools First[1129]: Cannot find function pointer NewPlugIn for factory C5A4CE5B-0BB8-11D8-9D75-0003939615B6 in CFBundle/CFPlugIn 0x7ff627a117f0 </Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin> (bundle, not loaded)
iMac 27 inches , late 2012, Quad-core, 8 GB ram, Fusion Drive, 3,4 GHz Intel Core i7, MacOs Mojave 10.14.6, Focusrite Saffire Le, thunderbolt adaptor, 800/400 FW cable. Last edited by stratquebec; 08-22-2015 at 08:46 AM. |
Hello,
I was wondering if you were able to rectify to your problem. I appear to be having the exact same issue. If I open a template the application becomes unresponsive right away. If I don't use a template the interface opens but becomes unresponsive as soon as I insert the XPand2 instrument.Like you, Reason, Logic, Ableton all run fine. |
No, not able to rectify anything.
I gave up and I'm done with PTF. Good luck.
BFD causing audio freeze in PT 8 | joedexter23 | The Drum Room | 1 | 03-26-2012 09:09 AM |
mbox 2 pro causing computer to freeze | trustlove | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-04-2011 06:38 AM |
Midi recording causing my system to freeze | sircharles2 | MIDI | 2 | 04-16-2007 05:31 AM |
MIDI Recording causing Protools to Freeze | mushmouth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 06-12-2004 01:14 PM |
ATA/66 Controller causing freeze at boot | Shaneo1234 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 06-14-2001 11:31 AM |
