  #21
Old 09-30-2019, 02:47 AM
Henning Svoren Henning Svoren is offline
Default Re: Pro Tools 2018.12 Not Loading at Certain AAX Plugins
Originally Posted by AnnexProjekt View Post
When you say "clean reinstall", did you do your whole system, or?
Thanks for bringing up the iOS stuff, not sure if there's a correlation but it's not impossible.
Yes, everything.
Got pretty pissed off by troubleshooting in the end.
Have worked very well since.
www.oceansound.no
  #22
Old 10-05-2019, 08:14 AM
AnnexProjekt AnnexProjekt is offline
Update on issue: Avid sent out an email about this stating they are aware of this and that iOS 13 was indeed the culprit and its isolated to Sierra 10.12. They said they’re working on this and noted that updating to high Sierra would rectify the issue. Also not to plug into iOS 13 devices into you Mac. Supposedly they’re working on a fix for the problem but that’s where they left it.
Anyone have a fix aside from updating?
@MrAnnex
[ MacBook Pro Retina - 2.7 GHz Intel Core i7- 16 GB 1600 MHz DDR3 - MacOS 10.12.6 - PT 2019.5 - Scarlett 18i8]
  #23
Old 10-06-2019, 12:39 PM
the19thbear the19thbear is offline
Saw that mail as well. Good stuff. Waiting for a fix. Have not found a fix. Just waiting for one.
  #24
Old 08-01-2020, 08:00 PM
Brettster Brettster is offline
I had this exact same issue and just found a fix that worked for myself. I went to my plugins folder and moved all the izotope plugins into the “plugins (unused)” folder (or whatever temp folder you like). Then I fired up Pro Tools and loaded a session. Then quit pro tools, put the plugins back in the folder and started up again and it worked. So stupid, but a lot less painful then reinstalling everything.
  #25
Old 04-15-2021, 06:49 AM
Marcel610 Marcel610 is offline
Hey guys!
I'm having a similar issue but with PT 2021 and Izotope RX8. After some trial and error (trashing some of the AAX files and rebooting) I found out that the plugin last displayed isn't the plugin that's crashing PT!
In my case it was the iZRelayHook.aaxplugin but the scan ran up until 5 to 6 plugins further. That's why it keeps showing a different plugin when you trash the plugin that was displayed last.
I don't know why this iZRelay thing keeps crashing my PT nor what it is for but I reached out to the iZotope support and I'll keep you updated!
Marcel
Pro Tools 2018.12 crashing when loading Vienna Instruments plugin at startup SuperKons Pro Tools 2018 7 04-22-2019 05:02 PM
Pro Tools 2018 slowdown and skate plugins Stevenk734 Pro Tools 2018 12 05-18-2018 06:21 PM
Pro Tools 12 Screen glitch when loading plugins slugblood Pro Tools 12 7 02-02-2018 03:18 PM
Pro Tools 10.3.8 Crash When Loading Plugins jahylto Pro Tools 10 5 10-10-2014 10:13 AM
Pro Tools Not Loading New Plugins SteveWitt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-24-2010 01:03 PM
