Memory Location question
When I start to record and need to start from the same section/spot, what is the way to set up the memory location (I believe its called) to go directly back to where I started recording? on another note-I have received a ton of great help here, thanks to all, its very much appreciated
Re: Memory Location question
you push Enter on your numeric pad to create a memory location.
You can then click on the marker in the ruler to go back or type in the memory location #. marker 1= .1. marker 15= .15. etc. to make a memory location with a specific # its .(number)Enter(numpad) ex= .99Enter
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
There is a section in the Audio Recording chapter that covers this. Just do a search in the PDF manual for "Memory Locations".
You should also review the option to "Link Timeline and Edit Selection" which is very useful for that as well as "Dynamic Transport Mode" which also may do what you want.
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
dumb question: insert memory location during playback? | Submersible | macOS | 11 | 05-17-2011 12:23 AM |
Memory Location Question | tomhartman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-02-2009 05:50 PM |
Memory Location Question | midnightsun | ICON & C|24 | 11 | 01-23-2009 06:24 AM |
Memory Location | mmf78 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-02-2007 01:15 PM |
6.1 bug: Can't add memory location | tal herzberg | Pro Tools TDM Systems (Mac) | 1 | 07-31-2003 01:01 AM |
