Arturia V not working with PT10
I'm having issues with setting up Arturia V collection 5 with Pro Tools 10
I can't seem to get PT to recognise the files, it says that certain files are moved to the un-used folder on start up and i'm guessing i need to transfer these files into the used folder but everytime i do, it says it can't find them (also they don't look like the same file types). I've also had issues with Addictive Drums 2 not being recognized, although Addictive Drums 1 is and works fine. Can anyone give advice? Thanks. |
Re: Arturia V not working with PT10
Hi and Welcome to the Community
Here are the specs for PT10 and up. Required configuration Works in Standalone, VST 2.4 (32-bit and 64-bit), VST 3 (32-bit and 64-bit), AAX (32 bits with PT 10.3.8, 64 bits with PT 11), Audio Unit (32-bit and 64-bit), NKS.VST 2.4VST 3 AAX AU NKS You need Pro Tools 10.3.8 minimum for use of the aax32 bit. If you don't have 10.3.8 it won't run. Update from your Avid account to the latest PT10 and you should be good to go.
I'm still using Pro Tools 10 HD here and I have the Arturia 5 collection. I can load all of them but certain ones still crash Pro Tools. Mini V is one of them. The older Mini V still works. Also, the new free MiniFilter plugin crashes the system anytime that you attempt to instantiate it. It's too bad because they make some pretty cool sounding stuff. Let us know how it goes once you get them to show up, probably by getting the last upgrade for Pro Tools 10.
DeckLink Studio 4K pci video out not working on PT10.3.8, but working on PT 11.3.2 | abes | Post - Surround - Video | 3 | 04-18-2016 01:19 PM |
Arturia Spark 2 - $100|Arturia Spark EDM & Vox Continental including eLicenser - $100 | hatepop | Buy & Sell | 2 | 10-26-2014 06:46 AM |
ARTURIA SPARK WORKING in PT 11 | cstars | AAX Plug-ins | 0 | 08-02-2013 10:37 AM |
ELS Vocoder not working in PT10/ML | powerjoe | macOS | 0 | 03-05-2013 07:47 PM |
PT10 working off of a NAS | Frank Kruse | Post - Surround - Video | 19 | 01-27-2012 04:27 PM |
