Old 06-12-2009, 08:30 PM
DJ FADE DJ FADE is offline
Default Pro Tools LE 8 Not Writing Send Automation
I'm trying to automate a send in Pro Tools LE 8 cs2, on a mac pro, and for some reason it's not working! I put the track in write/touch/latch automation modes, and it's not responding to any of them.
Is there a setting I changed somewhere that would not allow me to automate a send level?
Thanks!
Brandon
Old 06-12-2009, 08:52 PM
flommer flommer is offline
Default Re: Pro Tools LE 8 Not Writing Send Automation
Only 2 things seem to have control over this...
The SAFE button on the individual tracks
or
The Automation window, where you can globally disable automation
If you open the controller lane for the send, any automation moves that are benin recorded should appear in red as the track is playing.. Is this happening for you?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 06-12-2009, 09:04 PM
SAFE button is not engaged. And when I'm on the controller lane for the send level, with automation enabled, it is NOT registering any movements that I make.
So weird! I've done this 1000 times and it's always worked!
Old 06-12-2009, 09:09 PM
I'd say time to dump your preference files...
From the trouble shooting thread:
Delete Pro Tools preferences.
-Go to Users > “your user name” > Library > Preferences
-Delete 'com.digidesign.protoolsLE.plist', 'DAE Prefs' (folder), 'DigiSetup.OSX' and 'Pro Tools preferences'.
-Empty trash, then restart the computer.
You can also use the Pro Tools Preference and Database Helper to trash preferences and databases automatically, as well as providing a few other useful tools. (This application is provided by a 3rd party and is not tested or supported by Digidesign)
Old 06-12-2009, 09:21 PM
just trashed prefs and databases... no luck!
any other ideas?
Old 06-12-2009, 09:25 PM
Try a new session and see if it has the same problem. If no, then your original session might have issues. You can import all the audio/MIDI etc from your old session into a new session and try again..
That's about all I can think of...
Old 06-21-2010, 01:41 PM
jtree93 jtree93 is offline
Did you ever get this fixed?? I'm having the exact same problem now. Have written automation 1000 times and it's not recording now.
Old 06-24-2010, 03:19 PM
kcfroines kcfroines is offline
if your on a mac, hit command + 4(numeric pad), it brings up a window where you choose which information will be written (pan, volume, mute, and I believe sends is an option in there too... but I can't check right now...)
let me know if this helps!
Old 08-19-2016, 10:43 AM
CPerdomo CPerdomo is offline
I'm having the same problem now... I can't continue my mixing. I know it has to be a setting.
The track reads: auto read, auto latch, etc... I can change it but it won't do a specific area. Not only if I cut it in sections.
Please help!
Writing Wah automation from GR5 tha]-[acksaw General Discussion 1 02-14-2014 12:44 PM
Writing Automation to Multiple Clips in Pro Tools ericlawrence macOS 1 01-10-2014 02:47 PM
Writing send automation with controller tha]-[acksaw Tips & Tricks 7 11-21-2011 10:22 AM
automation issues (re-writing automation when it shouldn't) revere 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-13-2008 03:41 PM
Writing Automation In PT? peneslapepe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 05-07-2002 05:09 PM
