Old 05-01-2012, 04:55 PM
rcd rcd is offline
Default Ran out of outputs on Digi 192...Need more
I'm mixing with a Digi 192, 8 inputs and 8 outs...PT 8.1
I'm using 2 of my 8 outputs for the monitors and really need those for mixing so I can use all my outboard gear simultaneously.
Is there any other way to route the monitor outs other than using up 2 of the analog outs? Would a D-Box or Central Station help free up the 2 Outs I'm currently using? Any way of using the headphone outs of my Command 8 to run the monitors while still maintaining a pure signal? Could I sync another converter with my Digi 192, like a 2 channel Apogee or Lynx to add 2 more outputs? Any other solutions for freeing up the 2 outputs while still running my monitors?
Thanks!
Rich
Old 05-01-2012, 05:35 PM
Craig F Craig F is offline
Default Re: Ran out of outputs on Digi 192...Need more
you can ether get another DAC card or some form of Digital to Analog converter and use some of your digital outs
or a monitoring box with digital in's would work but I'm not up on what's what in that area
Thank you,
Craig
Old 05-01-2012, 08:23 PM
nst7 nst7 is offline
And try not to post in 3 different sections with the same question.
Old 05-04-2012, 01:24 AM
Roland Clarke Roland Clarke is offline
A cheap and chearful solution would be to print your tracks, send another couple and then print those, other than that you need to buy an additional card for your 192 or loose some of your outboard and work in the box.
Digi 003 outputs (trs or ts) ???? basslik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-28-2010 02:42 PM
digi 001 outputs tonicband 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-15-2001 02:52 PM
Digi 001 Outputs David Lawler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-07-2001 05:31 PM
More outputs on Digi 001. HOW??? DJ BIZZ-E 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-17-2000 06:55 PM
Digi Outputs Slim Shady 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-09-2000 04:54 PM
