Pro Tools 12 vs 2018 which is better for my setup?
Hello
I'm on the verge of upgrading PT 10... which has been rock solid From a certain point of view I'm not too worried because, following Avid suggestions, I've always had pro tools rock solid since version 8... yeah, problem here and there, but except certain versions with certain os version, I never got any problem of stability But, considering I have a Mac Book Pro mid 2014 (quad core i7 2.2ghz), I was wondering which would be the best version for my computer (I've noticed some of just a year before can't already go past 2018.4 ... so I'm wondering if I'll be starting noticing some speed and stability impact there I'm talking both PT and OS version My MBP had Yosemite when it came out (actually was refurbished so I discovered I could install Mavericks, so I installed it and used PT10 since now) When I upgraded from Yosemite to El Capitan I noticed a huge improvement (but I'm talking only about internet and everyday use, I have a partition I use only for internet and stuff) and I'm still not sure if high sierra is at el capitan level (on an everyday use) So, what I'd like to find is which is the best version of PT and OSX I should use to not notice any speed and stability difference between PT10 or PT12/2018 Thank you |
Re: Pro Tools 12 vs 2018 which is better for my setup?
anyone?
thank you |
I will leave the real answers to the Mac users, BUT....Whatever you decide to do, have a backup plan. Moving to the current PT version probably will require an OS update as well, so with that in mind, I would start from scratch. Remove the current system drive and install a fresh SSD and load up the current OS, current Pro Tools and the latest versions of every plugin you have. DO NOT try to update the old drive. Reasons?
#1-with PT10, every plugin needs to be updated #2-updating will leave behind tons of useless files #3-if your new build has issues, you can still put the old drive back in and get work done(never update in the middle of an important project) Last 2 cents while we are talking about a backup plan; if your sessions only exist on one drive, its time to back them up(as in DO IT TODAY)
There's plenty of differences between PT10 and and any modern version of PT. 64 bit versus 32 bit for one - bigger address space. PT12 and up has a user specified ram cache which if you're on an old system with a spinner system drive but have a lot of ram will speed things up immensely. Something to be aware of is that PT10 was the last to use RTAS plugins and was the bridge to the more modern PT versions with aax plugin format. PT11 and all later versions use aax64 - check with your plugin developers as they may well have aax 64 versions of what you have now. If you upgrade now I don't believe you can get PT12 unless you buy a used license. All I think you can get from Avid is PT2018. Pay no real attention to what year computer is considered compatible. Of more importance is how much ram do you have in your current machine and what exactly do you have for a system drive? You want to have at least 8 gig of ram and 16 gig if you can swing it. Once you have that down then start to think about specific OSX versions. And there's another stumbling block - a specific OSX versus what work with current PT versions. If you take a look at a couple of threads here there are people who are wrestling with that specific deal. Here's but one such thread: http://duc.avid.com/showthread.php?p...65#post2498265 |
what do u think about having two partitions? now that i don't need to run two os, i could just do two user accounts, one for internet, the other one for pt I want to install mavericks and pt10 on an external hd, so i can always load old projects with it, and pt 12 or 2018 in the macbook with high sierra 10.13.3 |
I'm just trying to understand which pt and os versions would be the best for a mbp mid 2014 only thing i got for now is to use high sierra 10.13.3 because past 3 you get problems with low buffer settings, which i use other than that I'm not getting much informations, i haven't found many threads about it |
Ram cache came in 10 not 12.
on your macbook, same era as mine with just a bit of a slower processor (and can probably maintain turbo which mine can't due to heat reasons anyway)
OS 12.12.6 and PT 2018.7 is the way to go. cheers
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
os 10.12.6?
os 10.13.3 no? haven't you tried high sierra? I know 10.13.4 and after should be avoided, but till 10.13.3 shouldn't be fine? thanks |
I've heard high sierra has problems with hds, but my mbp came standard with ssd, so I think it is optimized for ssd... so, if that was the problem you were making me aware, I think I don't have it and actually should be better high sierra, am I wrong?
New Pro Tools 2018 Setup with Yamaha Midi Grand | danm190 | Windows | 16 | 07-28-2020 10:27 AM |
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations | matthewmkb | macOS | 0 | 06-27-2018 06:33 AM |
Pro Tools 2018 with Pro Tools Control on iPad - connection problem | JacobSoundStudio | Pro Tools 2018 | 4 | 06-25-2018 01:24 PM |
Latency with Pro Tools Ultimate vs. regular Pro tools 2018 | DualCoreX2 | macOS | 5 | 04-25-2018 08:17 AM |
Upgrading from 2018.1 to 2018.3 with Application Manager | lm183902 | Pro Tools 2018 | 2 | 03-19-2018 04:41 PM |
