Old 07-05-2019, 08:47 AM
eddhartwellmusic eddhartwellmusic is offline
Default Logic Pro with HDX
I'm sorry if this has been posted a million times before, just trying to work it out for my specific rig.
I'm, trying to use the HD I/O interface with Logic, but Logic doesn't see the HDX card.
I'm running OS X 10.11.6
Pro Tools 12.5.0
Logic 10.3.3
I'm aware that I'm running old software, unfortunately that's the way it is at the moment.
Any help welcome
Old 07-09-2019, 06:30 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Logic Pro with HDX
Pro Tools can't be running. CoreAudio will find the HDX card if not in use.
Launch Logic then set up your I/O in Logic
Assuming HDX / HD Driver is installed properly.
(Help us Help You)<<<click here
Testing:All APFS 90% 10% Audio on HFS+(Testing 1.5 yr in)
Pro Tools U-2019.6 MacOS 10.14.6
Second boot-10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MacVCEdition, 3-Displays)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDI over IP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
Old 07-10-2019, 04:38 AM
Thank you for your reply, I was aware to start it without Pro Tools running, but still no joy.
I'm assuming the HDX/HD drivers are properly installed as Pro Tools works perfectly.
If they aren't properly installed, I obviously can't install the latest drivers available on the Avid website, is it possible to find and download the relevant ones anywhere?
Old 07-10-2019, 05:56 AM
HD drivers show up on your Avid account
Old 07-10-2019, 06:56 AM
BScout BScout is offline
That is NOT an indicator. Pro Tools does not use the Core Audio drivers that Logic does.
Additionally, you need to install those drivers separately. (they are in a subfolder of the Pro Tools installer and also available separately in your My Avid account)
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Logic pro and logic pro x doesn't work after mavericks Sanderb Artist Series 3 12-20-2013 12:13 PM
Logic 8 to logic 7 session won't open! saving procedure need crizdee Pro Tools TDM Systems (Mac) 9 04-26-2008 08:09 PM
Logic Pro users: Midi & audio between Logic & PT dtmprod Pro Tools TDM Systems (Mac) 4 09-24-2006 04:16 PM
Logic 5.0.0 crashes all the time.. Is there a Logic expert around here? uno1234 Pro Tools TDM Systems (Mac) 13 04-28-2002 04:23 PM
Hello Logic users.......Please explain about Logic Midi elik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-04-2001 12:35 AM
