Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 03-31-2020, 06:38 PM
GOOOTOOO GOOOTOOO is offline
Default What can a Midi track do that an Instrument track can't?
I don't understand why midi tracks are kept around as an option. It seems like everything they do can be done with a Instrument track, plus more.
Old 03-31-2020, 07:07 PM
massivekerry's Avatar
massivekerry massivekerry is offline
Default Re: What can a Midi track do that an Instrument track can't?
You trolling?
Some people still use Outboard Gear. Sometimes you only want a MIDI track to feed data to plugin that follows pitch or CCs (like VocalSynth, Auto-Tune, etc) and for folks like me, who have hundreds and hundreds of Instruments loaded in a server like Vienna Ensemble Pro, it's just better and more stable to have Pro Tools only sending MIDI to all of those tracks, instead of adding the load of hosting those instruments being put on the CPU.
Old 03-31-2020, 07:17 PM
This is definitely just because I'm a noob but could you elaborate on a few of these examples?
I don't understand what you mean by this. For example with autotune, are you saying you would use some aspect of midi data to control the automation of autotune being applied to an audio track?
So you have a server full of VSTs, and it is easier to send midi out to the server and then back into pro tools, then to just have the VSTs in pro tools?
Old 03-31-2020, 09:50 PM
All good.
Here's a video showing how to use a MIDI Track to set pitch and harmonies in VocalSynth 2.
https://youtu.be/WCaIlGXikjw
You can do similar things with AutoTune. Also Stutter Edit is placed on an Audio, Aux or Master Tracks, but you trigger the different scenes via MIDI, so it's nice to have a MIDI Track assigned to that.
Yes, exactly. If you start loading up instances of big orchestral sample libraries in Pro Tools, you'll notice it dragging pretty hard after more than a handful. It's more CPU-efficient to have them hosted outside of the DAW, with multi-timbral instances being "played" by MIDI tracks, with the audio returning via Instrument or Aux tracks.
Here's an example using Pro Tools:
https://youtu.be/yd5ChozAys4
and here's a good explanation of how/why you'd want to do that in any DAW if you're doing this kind of work.
https://youtu.be/bB1twfL5b28
Old 03-31-2020, 09:56 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
I work with instrument tracks 95% of the time, but sometimes midi tracks come in handy. Mostly for older VI's that are multitimbral, but don't have separate outputs.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 04-01-2020, 12:54 PM
@massivekerry
Thank you those videos were very helpful for understanding. Do you do composition in pro tools for film or anything? If so, I was wondering how you got into that.
Old 04-01-2020, 12:59 PM
jeffro's Avatar
jeffro jeffro is offline
It can also give you easier access and control to work on parts (on separate MIDI tracks) that are triggering one VI (on an Aux track), especially if the parts/notes overlap ranges.
linkedin
Old 04-01-2020, 02:32 PM
bashville bashville is offline
I also like seeing all the instrument setup information without losing that extra column of right-left space. If I use a midi track to control an instrument in an aux, it creates an extra track, but for some reason that bothers me less than losing the horizontal space in the edit window.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur
Old 04-01-2020, 02:46 PM
EGS's Avatar
EGS EGS is offline
+1
Click for audio/video demo
Click for resume
Old 04-02-2020, 09:19 AM
Eric Lambert's Avatar
I very often feed multiple MIDI tracks into a single VI, using different MIDI channels of that VI. Instrument tracks don't allow that.
Print audio from Midi Track (not Instrument Track) hardcase macOS 32 10-08-2015 05:51 AM
copy instrument track to midi track trev1238 Pro Tools 9 5 02-04-2012 01:16 AM
Difference between Midi Track & Instrument Track better? paul Neathery 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 07-16-2007 04:03 PM
Mapping MIDI Track To Instrument Track Delta Dreams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-08-2007 11:26 AM
midi outputs? aux track or instrument track? pikapikapi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-19-2006 02:28 AM
