RME HDSPe and Digiface Issues
My RME gear has got to go since it doesn't play nice with ProTools but til then I have an issue.
I was experimenting again with changing sample rates from 44.1kHz in ProTools with my RME gear. I changed it to 96kHz and it was very difficult to get a ProTools session back to 44.1kHz. I have sessions working at 44.1kHz at 64 buffers, but the delay is far greater than 64 buffers. I uninstalled PT and the RME hardware and reinstalled. The delay is only in PT - Reaper latency is as would be expected. Any ideas on how to get ProTools to get realigned with the RME gear? Dave
Re: RME HDSPe and Digiface Issues
FYI - its only some old sessions. I am not sure whats causing it yet.
Does anyone else have issues with RME gear and changing sample rates?
Dave,
I run PT11 with an RME HDSPe AES card from a Lynx Aurora 16 on a Win7 machine. It really works great for me. But juggling sample rates does take a bit of discipline. Before opening PT, I have to make sure the Lynx, RME, and PT session rates all line up. I incorporate the sample rate into the file naming convention for PT sessions so I can make adjustments before starting PT. Mo |
Thanks - I have gotten to work somewhat by making sure PT is shut down and the RME gear is set to the appropriate sample rate before opening a session. I have a session that appears to somehow got corrupt after opening on a sample rate change. I can play it at the appropriate Sample Rate - but it now has some odd thing going on with latency. I checked delay compensation etc, but the session for no explainable reason to me has a great deal of latency. If I delete tracks to make the session an audio track and a master track the latency disappears. Have you ever had a similar experience with a session? If I cant reliable jump sample rates and the latency being tolerable on existing projects - it just isn't going to fly. Dave
I am only updating this post for reference if someone searches RME HDSPe compatibility with Pro Tools.
I have been very carefully experimenting with creating projects at 44.1 and 96kHz and changing the hardware sample rate and then opening projects. I have not found a way to do it reliably with my:
When opening projects the interface is automatically changed to the wrong sample rate and then PT throws an error. Once I do get a project too open. It has an increased level of latency. If I then create a duplicate new project there is no additional latency.
RME HDSPe/Digiface Sample Rate | txshonk | Third Party Interfaces | 2 | 01-22-2015 07:10 AM |
RME HDSPe User | txshonk | Pro Tools 11 | 1 | 10-03-2013 09:58 AM |
Help Mapping I/O for 2 RME HDSPe Cards | bigredsound1 | Pro Tools 10 | 3 | 06-02-2012 10:49 AM |
Low latency monitoring, RME HDSPe | Trazan | macOS | 0 | 12-15-2011 04:20 PM |
PT9 with RME Digiface? | kevkon | Pro Tools 9 | 6 | 02-08-2011 12:09 PM |
