DIGI 003 + PT10 + Win7 64bit = Don't work
Hello everyone!
I'm having problems with my PC trying to load Pro Tools 10 with a Digi 003 Rack. I try to find the solution in different forums, but all I can find is very old threads and can't find any solution yet. The problem is that Pro Tools does not recognize my Digi 003. I try several things. The last time I installed the driver I went like this: 1 - Uninsitall everything (PT, driver, and everithing related) 2 - Install driver (with the Digi disconnected) 3 - Reboot 4 - Install PT10 (with the Digi disconnected) 5 - Reboot 6 - Turn on Digi 003 Pro Tools opens, but the it saids that it's not possible to inicializate the ASIO audio device. That I have to choose a different audio device. I have a: Intel i5-2500 @ 3.30GHz - 4GB RAM - Windows 7 Ultimate 64bit. My firewire board has Texas Instruments chipset. I have to make myself a Sandra report, because I don't know why, the computer overview crash. This is the Sandra report that I compile: SiSoftware Sandra Computer Model : GigaByte H61M-S2V-B3 Chassis : GigaByte Desk Mainboard : GigaByte H61M-S2V-B3 Serial Number : BIOS : 04/11/2011-H61-7A89WG02C-00 Total Memory : 4GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i5 CPU @ 3.30GHz Socket/Slot : FC LGA1155 Chipset Memory Controller : Intel Core (Sandy Bridge) DRAM Controller Memory Module(s) Memory Module : Kingston 99U5471-012A00LF 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : Samsung Video Adapter : AMD Radeon HD 6450 Graphics Processor Compute Shader Processor : AMD Radeon HD 6450 Storage Devices WDC WD20EARS-00MVWB0 (2TB, SATA300, 3.5") : 2TB (D:) WDC WD5000AADS-00S9B0 (500GB, SATA300, 3.5") : 500GB (E:) Logical Storage Devices ????? (I can't find this. I don't think this is relevant) Peripherals LPC Hub Controller 1 : GigaByte H61 LPC Controller Audio Device : GigaByte Cougar Point High Definition Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : Pine Technolgie NI Caicos HDMI Audio [AMD RADEON HD 6450] Audio Codec : ATI (AMD) NI Caicos HDMI Audio [AMD RADEON HD 6450] Disk Controller : GigaByte Cougar Point 2 port SATA IDE Controller USB Controller 1 : GigaByte Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : GigaByte Cougar Point USB Enhanced Host Controller #3 FireWire Controller: TI XIO2200(A) IEEE-1394a-2000 Controller (PHY-Link) SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes ????? (I can't find this. I don't think this is relevant) Network Services Network Adapter : Atheros AR8131 PCI-E Gigabit Ethernet Controller (NDIS 6.20) #2 (Ethernet) Wireless Adapter : Atheros AR9285 Wireless Network Adapter (802.11n (HT), AES-CCMP, 150Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 |
Re: DIGI 003 + PT10 + Win7 64bit = Don't work
leodalmaso85,
Is this 003 rack known to be in good condition? Have you tried it on another computer? Have you "hot plugged" (firewire) the unit lately? This can destroy the firewire port on the 003.
Thanks for the replys!
TOM@METRO: I already tryed the 003 on other computers, and it worked just fine. I don't think is a problem of the 003, I think is maybe a driver issue. 68Tele: I have installed several software like Cubase, Live and Reason, and don't work in any of these! I'm going to try to re-install Win7, I hope this works. Do you see any problems in my hardware? Do you think that maybe some other hardware like the video card could be the problem? Thanks to both of you! |
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
If anyone has a new idea I will be grateful! If not, I think that I have to restart and reinstall everithing |
I already try it on a friend computer! So I think I have to reinstall everithing!
Just to be clear I'm talking about changing the Windows FW driver. If you right click the FW chip in Device Manager and select "Update Driver" then "I will pick the driver manually" you should be given a choice of a drop down Menu with three choices. Something like Legacy 1394 Driver, TI 1394 Driver and OHCI compliant driver. Try each of the other choices. Just toggling the choices has been know to make a difference.
I'm not at my Win7 machine at the moment. So I'm paraphrasing the instructions. If you right click the Device in Device Manager I'm fairly sure that you will be able to work your way through the process.
I reinstalled windows 7 and the driver. I tried to listen something with the window media player, but still nothing. I think this is one of those cases that the Digi doesn't work and there is no solution.
I tried to change the FW board driver, but still nothing. If someone has any other ideas I will be grateful! If not, I'm going to change one of two things: the computer or the Digi |
Have you installed the 003 driver? With PT9 and 10, it is a separate install. Also, note that there is a separate driver depending on if you have the rack version(002/003) or mixer version(so get the correct driver). Once the driver is installed, and the 003 appears in device manager as a Sound device, that should be the turning point(but I will admit, I am less than optimistic about the computer)
Digi 003R & Win7 64bit-- is it compatible? | edwincalle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-10-2013 08:07 AM |
Constant Crashing! PT10.3.6 Win7 64bit | ReachMusicProductions | Windows | 1 | 08-07-2013 06:24 PM |
MIDI Out in PT10 on Win7 64bit? | 8dB.co.uk | Windows | 0 | 03-26-2012 11:33 AM |
PT10/Focusrite Scarlett/Win7 will not work at all | jacobpo2 | Windows | 2 | 01-10-2012 07:28 AM |
ASIO Drivers for Pro Tools 9 in win7 64bit DO NOT WORK | cdmstudios | Windows | 18 | 04-11-2011 03:24 PM |
