backing track help??
Ok so I'm trying to figure out how my band can use the backing tracks that I recorded in pro tools 8 live?? The problem I'm having is that I've panned the tracks left and the click right but the click is still lightly coming through the left and I can't figure out why. I've tried recording the click to a stereo audio track, then splitting it into mono and taking out the left and still the same result. I've tried making the output of the click out of just 2, the right, and still the same. So I'm not real sure how to fix the problem. Any help is greatly appreciated.
Cheers |
Re: backing track help??
oh and by the way I'm trying to run this out of ITunes instead of hauling around my 003 rack everywhere. Thanks!
I've seen this done successfully many times so review your panning and tracks. Is it possible that the click is being fed via an AUX send to somewhere? Or maybe someone had too much click in their phones when recording backing tracks and its really bleed onto one of your AUDIO tracks? Does it go away if you mute the click? If not, then solo each of your individual tracks and listen for click bleed.
If you are using itunes to create an .mp3 track make sure you change the settings in itunes to "normal stereo" and not "joint stereo". Bounce your main track from protools with your panning hard left/ right whatever into a stereo track, then create your .mp3 as folllows. my buddy had the same problem. hope this helps!! if all else fails, use a free 3rd party converter called 'Max' to create and convert audio formats as well. -Doug
Mac Pro Dual Quad 2.8Ghz 2008 MacBook Pro i7 2012 OSX 10.8.5 - OSX 10.7.5 Pro Tools 10.3.7 - 11.1.2 6GB RAM Universal Audio Apollo Quad!!! Eleven Rack Focusrite Octopre MKII Yamaha HS80s Rockit RP5 Monitors w/ RP10 sub |
+1
2.66GHz Quad-Core Intel Xeon 6 GB SDRAM 3 1 TB WD Caviar Black Hard Drives Eleven Rack, Axiom 61 |
Well its def. not headphone bleed bc eveything was done straight DI and its really mostly a bunch of synth and keyboard stuff. The click does go away if you mute the click track itself and its 100% panned. But even when I solo the click I can still hear it just barely out of the one side its not panned to at all. I don't get it. Ha.
Are you using a separate hardware mixer? It could be crosstalk on the channels or master out from that.
A:)
I Love Audio!!! |
Can you post a screen shot of your mix page?
hmm I'll try too. Not totally sure how to do that but I'll make an attempt. Thanks for helping me too.
I have had the exact same issue happen without any solution to a fix.
My band at the time just had 808 hits for our backing track. So absolutly no chance of bleed from headphones or anything. 808s on mono track panned all the way to the left and click track panned all the way to the right. when I created the wavs all appeared fine. We loaded the samples onto a Roland SDP-8 sample pad and ran them through our PA at practice and noticed that we were hearing a click track. The only thing I could think that caused this was the sample pad because thats the extra piece in the chain. |
Making a backing track and have some issues | bryced87 | Tips & Tricks | 5 | 01-19-2014 10:59 PM |
What is the best backing track worklfow? | barters81 | The Drum Room | 9 | 02-07-2011 12:02 AM |
Click Track / Backing Track Issues... | StarSonicEnt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-02-2007 03:24 PM |
what is the most reliable backing track HD player? | digidesigner | General Discussion | 1 | 08-29-2005 12:28 PM |
Backing Track Help | makerthemaker | Pro Tools TDM Systems (Mac) | 1 | 09-09-2002 10:25 PM |
