Old 01-30-2018, 06:16 AM
Cabra Cabra is offline
Default Aae 6089
AAE 6089: The operating system held off interrupts for too long. If this occurs frequently, try increasing the "H/W Buffer Size" in the Playback Engine panel.
I have my system optimized per Avid's recommendations. I updated to 2018.1 but I was still getting this problem with 12.8.3.
I have changed the H/W buffer size to the max, then it tells me to lower it, I lower it, then it tells me to increase it....Any thoughts on the problem?
Mac Pro 3,1 20Gb Ram
Dual 3.0ghz xenon processor 2TB hard drive
OS 10.11.5
Protool 12.8.3
003+rack
Golden age Pre 1073
Hello there.
Old 01-30-2018, 12:00 PM
gmu gmu is offline
Default Re: Aae 6089
There is a lot of information about this here but you’ll have to search deep for it. If I recall correctly it’s in large part to do with the video card that comes with some of the MacBook Pros. Of course a contributing factor is how complex your session is...plug-in count and bussing config. On sessions where this is a constant problem I’ve resorted to committing or freezing as many tracks as I’m comfortable with. Good luck!
MBP 2015 3.1ghz i7 16gb Big Sur
Pro Tools 2022.10
UAD Apollo 8p / Octo
Error -6089 in XP oregafro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 07-22-2009 08:29 AM
-6089 Hell! colfaxrevolution 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-23-2009 07:58 AM
6089 error... again !!! DanyL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-22-2004 11:53 AM
-6089 error Steel City 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-10-2004 10:53 AM
6089 Issue Jaenus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-10-2004 06:59 AM
