Old 06-12-2003, 04:37 AM
livstone livstone is offline
Default G4 Titanium and G4 Tower
Hi-
I am looking for the best way to connect these two computers from time to time in order to easily do back ups and copy data. I tried doing the ethernet thing but had no success up to now.
If any one has any info on this I would appreciate it.
Thanks
Wayne [img]images/icons/rolleyes.gif[/img]
Old 06-12-2003, 04:57 AM
peteri peteri is offline
Default Re: G4 Titanium and G4 Tower
Assuming both have firewire...
I've got an OS X only powerbook and if you hold down T while it's booting up - it becomes a firewire drive, you can then just plug a firewire cable between the two machines and drag and drop away.
Did this yesterday and it works perfectly, just remember to eject the firewire drive before disconnecting (select drive and hit apple e).
Don't know if this will work for you - but worth a go.
Very fast too.
Pete
Old 06-12-2003, 05:09 AM
audiobob's Avatar
audiobob audiobob is offline
peteri is correct and it works great.
Here's an Apple document on FireWire Target Disk mode.
Old 06-13-2003, 09:53 AM
Thanks for the info guys. Will this work under OS 9.2 also?
Old 06-13-2003, 10:41 AM
Henry Lee Henry Lee is offline
yep.
I've done it between 2 Tibooks and even an
old 466 Clamshell iBook.
Cheers,
Henry Lee
Old 06-13-2003, 11:14 AM
etherize etherize is offline
why use firewire over ethernet? is using firewire faster?
Old 06-13-2003, 04:03 PM
Tried it and it works like a charm. But that is a good question about the ethernet thing. However this way has got to be alot easier than setting up for ethernet.
Thanks again guys.
Wayne [img]images/icons/smile.gif[/img] [img]images/icons/smile.gif[/img]
Old 06-13-2003, 04:12 PM
Be cautious tho'.. don't connect the FireWire cable while either Mac is powered up or sleeping.. I smoked the logic boards in both Macs by doing that.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 06-13-2003, 04:40 PM
Muzza Muzza is offline
Unless you have gigabit ethernet, FireWire is faster in all cases. The advantage of ethernet is that it can be always connected and that it doesn't require you to restart one of the G4s to activte it.
What did you try in order to get ethernet going?
PS. I just read the doc on FW targets (TDM!). That is so incredibly cool!
_ _ _ _________ _ _ _
Murray
Old 06-13-2003, 06:57 PM
s2n s2n is offline
Soon, Apple will be releasing TCP-IP over FireWire. They have it for their XServer already. Then, your Macs could stay connected over FireWire.
best G4 tower for 002 ? dente123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-19-2003 10:05 AM
titanium w 002 kidfrenzy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-22-2002 06:08 PM
G4 Titanium with SSD and PT Mix+ storymaster Pro Tools TDM Systems (Mac) 6 09-27-2001 05:55 PM
Titanium PBerolz Pro Tools TDM Systems (Mac) 26 05-21-2001 12:22 AM
Titanium PBerolz Tips & Tricks 5 04-20-2001 08:46 AM
