48 kHz (Ext. clock)
I am trying to set my sample rate to 44.1 kHz but Pro Tools will not let me change it. I am attempting to put audio with 44.1 kHz into Pro Tools from Ableton. How do I fix this? Thank you.
Re: 48 kHz (Ext. clock)
Hi, What computer? What operating system? What audio interface? Chris
Hi, Kreskin here. I suspect he's on Windows and trying to use his interface for PT and Windows sounds/audio. OP, don't do this. Make your onboard soundcard the default for Windows sounds/audio and leave your interface ONLY for Pro Tools.
Hello. I apologize for getting back so late. My set up is: 16GB RAM, Asus Z-170AR motherboard, Intel i5 6600K 3.2 gHz, NVIDIA 1060 graphics card, Presonus audiobox. To my knowledge, Pro Tools is set up on my audio box ASIO driver. Is that what you mean? Thank you for the replies.
Make sure that the Presonus is only being used by PT and not Windows audio as well. If it is also selected under Control Panel "Sounds" for Windows audio, the sample rate is being dictated by Windows which is why you cannot change it.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
Problem detected with audio clock. Check your clock source and sample rate. | sleeptalken | Windows | 7 | 08-10-2021 01:17 PM |
Problem detected with audio clock. Check your clock source and sample rate. | teleguy2 | Windows | 6 | 06-26-2015 01:47 PM |
Problem detected with audio clock. Check that your clock source and sample rate are c | Solow1nonly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-06-2011 08:22 PM |
problem detected with audio clock. check that your clock source and sample rate are c | angeleda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-05-2010 07:09 PM |
"Problem detected with audio clock. Check that your clock source and sample......... | ASD15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 03-26-2010 03:40 PM |
