authorization on Timewarp 2600
My biggest gripe with Digi is how you're expected to jump through hoops in order to get everything you purchased. Once you walk out the door at your local Music Store your on your own. Trying to get someone on Tech Support is like an afternoon chore. Thank God for Spkguitar, he probably answers more questions than anyone and should be on your payroll!
I just purchased an 003, and the only thing in the box (besides the unit) was a 7.3.1 disk and the best manual I've gotten so far. So this means I had to download the 7.4 etc, etc. But there was absolutely nothing referring to the Ignition Pack 2! (disk or registration cards) On your support page it says if I didn't receive IP2 to contact my dealer and that they are not available from Digidesign. My dealer thinks I'm nuts and I cant get Timewarp authorized, fortunately my other plugs ported over from my older MBox 2 Pro without re-registering them but I'm not sure how...what gives? Sorry if I sound frustrated but you really wouldn't want to be me right now.
www.rickqueststudio.com |
Re: authorization on Timewarp 2600
Was the box sealed when you bought it?
Meanwhile my love/hate relationship continues!
The ignition pack is only available with a new hardware purchase. If the box was sealed (are you sure it hadn't been "re-sealed" by the dealer?), and there is no Ignition Pack disk inside, then the item purchased is "defective" (does not include everything it should) and you should "return" it to the dealer for replacement.
Dear Digi,
You should just open every post with "Spkguitar is spot-on with this" but this link and quote from the Digi site seems to suggest many boxes went out without IP2 and that this was a known issue: http://www.digidesign.com/index.cfm?...4&itemid=25023 "If you purchased a new Pro Tools|HD or Pro Tools LE hardware system from an authorized Digidesign dealer on or after March 1, 2007, and you did not receive your Ignition Pack 2, contact your Digidesign dealer directly. The Pro Tools Ignition Pack 2 and Ignition Pack 2 Pro are not available from Digidesign, and are not sold separately. They are only included with the purchase of new Pro Tools|HD or Pro Tools LE core hardware systems from your Digidesign dealer. Pro Tools M-Powered systems do not include the Ignition Pack 2 bundle." This is exactly why I said I needed to contact my dealer Monday...
The way it works is as I indicated in my post - we sent dealers enough IP2 inventory to cover their current stock. That link states specifically what should be done in the case that you did not get the IP2 that either should a) be in the box in the case of newer stock or b) have been given to you separately by the dealer in the case of older stock. In an ideal world, a new box will have a sealed IP2 or, if the stock was older and not packed with the IP2 inside, the dealer would have given you the IP2 separately. Obviously we know it's not an ideal world and that we would get questions from those whose did not get the IP2, either in the box (a packing error) or given separately by the dealer (a dealer error). In either case, it's the dealer that would deal with the issue. |
I do appreciate your response and understand how difficult it must be.
Timewarp 2600 Update-NO SOUND!? | C.E.G | Virtual Instruments | 2 | 12-03-2009 04:49 AM |
Re-authorize timewarp 2600 everytime I use it! | grayc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-11-2009 11:18 AM |
TimewARP 2600 Lite Crash on my Mac! | Pato-Wan Kenobi | Virtual Instruments | 0 | 04-03-2008 10:11 AM |
Timewarp 2600 CPU issue | Slowdive90 | Virtual Instruments | 0 | 09-11-2007 02:46 PM |
Problem using TimewARP 2600 with Pro Tools LE 7.3.1 | msk011 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-13-2007 04:26 AM |
