Old 01-22-2024, 02:46 AM
sasaking1122 sasaking1122 is offline
Default Melodyne ARA
Melodyne ARA on Protools 2023 12
Melodyne's screen display response and operation are extremely slow!:狂った:
Are there any improvements?
MacPro 2023 Memory 128GB MacOs Ventura
Old 01-22-2024, 03:19 AM
tope d's Avatar
tope d tope d is offline
Default Re: Melodyne ARA
Hi.
There are a few. You can check https://www.avid.com/pro-tools/whats-new
Have you already tried clearing your pro tools prefs?
Let us know if the same issue occurs after deleting your pt prefs.
Thanks!
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 01-25-2024, 07:43 AM
Parisstudio Parisstudio is offline
Don't bother using it unless you want to lose everything you did. It works fine if you edit and commit it before shutting down. If you don't and open the session everything is lost plus the track is out of sync.
Old 01-26-2024, 08:36 AM
Thenewexhibit Thenewexhibit is offline
Has this always been happening since ARA?
Melodyne Track mode SOMETIMES converts all clips to melodyne? CarlosDanger Pro Tools 5 11-03-2023 08:27 AM
Some Melodyne track data can't be found. Melodyne edits on affected tracks may not pl JingleDjango Pro Tools 27 02-07-2023 06:48 PM
Alternative to Melodyne for Audio to MIDI? Or Which Melodyne version? DBK Getting Started 6 12-15-2014 11:33 AM
Melodyne Users - Melodyne Editor Beta release imminent! Driven01 Pro Tools M-Powered (Mac) 2 09-18-2009 06:31 AM
Melodyne Users - Melodyne Editor Beta release imminent! Driven01 Pro Tools M-Powered (Win) 2 09-18-2009 12:15 AM
