Old 07-26-2015, 04:05 PM
kriskaudio kriskaudio is offline
Default MP3 adding extra time
I have a weird issue that happens when I create an MP3 in Pro Tools. It occasionally adds extra time (blank space) at the end of the file that is about 5 times longer than the audio. For example, if the audio I select is 16 seconds long, the total length of the new mp3 ends up being about 90 seconds...or a 3 minute file ends up being 15 minutes long or so. This happens either when I export or when I bounce. It's only occasional...kind of a roll-the-dice situation, as I never know when it's going to do it.
Any ideas why this is happening? I've done a reinstall, with no change.
System is a PPC G5, Pro Tools 7, 002 rack. (I know it's ancient, but otherwise works well -and is paid for!)
Old 07-26-2015, 04:10 PM
amagras amagras is offline
Default Re: MP3 adding extra time
Was the session longer than it is now? Check for old automation.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 07-26-2015, 04:17 PM
No automation. It's just a single mono track (voice over). I do have some plugins running on inserts. And nothing changes within the session after the mp3 is exported (session length exactly the same.)
Old 07-26-2015, 04:56 PM
Any hidden tracks? Did you tried exporting in other format like wav?
amagrasmusic.com
Old 01-25-2018, 01:11 AM
Mohamed Sathiq Mohamed Sathiq is offline
This problem occurs only if you export both wav and mp3 at the same time.
Try exporting a mp3 file alone.This will not add any extra time...
Adding extra Interface through S/PDIF steveos69 FireWire & USB Audio Interfaces (Mac) 16 06-21-2013 01:24 AM
Adding an extra bar before 1/1/000 cc1 Pro Tools TDM Systems (Mac) 3 03-28-2007 11:04 PM
Adding extra inouts to my digi 002 studio4610 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-02-2004 08:34 PM
Adding extra ins & outs DogSaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-28-2004 07:31 AM
Adding extra MIDI to PT LE Knightshow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-29-2001 11:26 PM
