Old 05-21-2010, 08:36 AM
tigerman tigerman is offline
Default sample accurate mutes?
Hi all , i have a series of mute automations over an audio track channel in pro tools, i've made those automations using "grid" mode so they are snapped to beats.
Main problem is that mutes are delayed a bit so when i mute i get a bit of the sound after the automation and when i un-mute i lose the sample start transient.
I've zoomed in and audio is perfectly in sync...
Is there any preference to set all automation sample accurate? else i have to go in "slip" mode and move all mutes manually.
It looks like it act in the same way with other automation aswell, i have a hp filter automation ina ff6 eq and i go from 300hz to 20hz without transitions, i had anticipate that a bit aswell, by the way i haven't tested it much..
Any clue please ?
thanks
Old 05-21-2010, 09:07 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: sample accurate mutes?
Any clue please ?
thanks
Set grid to samples?
Are you muting the audio track that has the regions on? or a bus fed by the audio track? if its a bus it will be out by any delay caused by the bus or any plugins on the bus.
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-21-2010, 09:34 AM
meech meech is offline
I've always noticed that mute automation seems delayed. You could select all your mute automation and nudge it to the left small amounts until it mutes the bits that should be muting ... I never use the mute automation now because of this. I just cut regions up and delete or mute the ones I don't want.
Old 05-21-2010, 09:38 AM
Brandonx1 Brandonx1 is offline
Hi Meech,
Do you have ADC on? ADC will delay audio but does not delay automation to match it. So, if you have 400 samples of delay from ADC, the mute sound late by 400 samples. As far as I know, Volume, mute, pan (anything with the pro tools mixer) is sample accurate. Plug in automation is not sample accurate.
Best,
Brandon
Old 05-21-2010, 09:44 AM
WernerF WernerF is offline
I've always wondered if the offset should be based on the ADC delay that is being reported by the audio track that you are mute, or whatever, automating or is it based on the highest total ADC delay in the session.
Old 05-21-2010, 09:55 AM
Both, and it acts the same, even on the audio track with no inserts at all, just the output.
Originally Posted by Brandonx1 View Post
Hi Meech,
Best,
Brandon
Yes ADC is on and i currently have about 1150 samples, this is the reason for sure!! that's why at the beginning of the project automations was nearly in sync while now they're not anymore, too bad! i wished there was an option to auto adjust them based from DC, so basically i just have to nudge back of the same amount of samples i currently have from Delay compensation on that track? or globally based from the delay compensation value displayed in the "session" option panel?
I mean is it global or track dependant?
Thanks to all for the advices!
MacPro 4.1 QuadCore 2.93Ghz OSX 10.5.8- 6GB Memory - PT HD2 Accel +96 +96i +AdatBridge24 - MOTU 2408+2408mk3 - ProTools 8.0.1cs2 + Logic 9.1.5
Automation is not sample accurate - if you need to mute something sample accurately, mute the region.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 05-21-2010, 10:01 AM
What about when you need to accurately mute a send to an effect, i.e. a reverb or delay. Does it just come down to trail and error or is the timing different every time as it is with midi at this point?
Old 05-21-2010, 10:04 AM
Yes, automation is considered a lower priority event in Pro Tools... It's no more inaccurate though than automation on any large frame console using SMPTE.
The main priorities are to play back the audio, then the automation and finally update the screen.
I assume you've played with the Automation thinning options, but that's for continuous automation not mutes.
Rail
Platinum Samples
Old 05-21-2010, 10:14 AM
Thanks for the info. I guess that it just comes down to giving the automation events a wider margin of timing error and hoping for the best result.
AC3, is it Sample Accurate? minister Post - Surround - Video 13 03-13-2007 10:57 AM
Sample accurate midi? Dopamine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-09-2005 11:48 PM
Rewire Not Sample Accurate? Siegfried Meier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-08-2003 11:41 AM
Stylus sample Accurate ? planet X Pro Tools TDM Systems (Mac) 14 01-11-2003 09:35 AM
