Old 07-23-2009, 06:21 PM
Phil Jeffers Phil Jeffers is offline
Default hold Shift and scroll via mouse wheel? (on Mac)
Hi guys,
Can anyone tell me where in Pro Tools 7 (for Mac) you adjust the setting / preference to allow the timeline move laterally when you hold down the shift key and roll the mouse roller? I love this function and use it all the time when mixing (as well as the option + roller wheel) but someone has turned it off on a system I use quite often and I can seem to find where to select it again.
Cheers,
Phil J
Old 07-24-2009, 06:09 AM
Carl Kolchak Carl Kolchak is offline
Default Re: hold Shift and scroll via mouse wheel? (on Mac)
As far as I know, there is no preference for that, it is the default behaviour.
I'm gunning for a feature request that gives us the option do have default scroll wheel behaviour as either :
Vertical (+ shift = horizontal) as it is now
or
Horizontal (+ shift = vertical)
Ideally this would be accessible from a drop down menu or directly in the edit window (making a short cut key a more reasonable possibility) rather than in the preferences dialogue.
Mind you, my recent feature request wasn't exactly a barnstorming success, but maybe it just got overlooked.
See what you think:
http://duc.digidesign.com/showthread...53#post1425053
I had problems with certain modifier keys suddenly not working in certain combinations on a PC using a USB keyboard.
Something got corrupted and for the most part, though not all combinations strangely, I lost the use of the "Start" key.
But only for short cuts, it worked in every other respect, and it worked in some key combos.
Perhaps you're experiencing something similar with your "Shift" key not effecting the horizontal scrolling?
Old 07-24-2009, 06:53 AM
Hi, thanks Carl
Somehow it has definitely been turned off... I've checked within Mac preferences, every possible Pro Tools setting, arrgghh! It's the same with LE & HD. I had it defaulting to that on a HD system, someone has disabled it somehow... I use it all the time while making tweaks to a mix with the multi-tool on the fly. I just hate using the arrows at the bottom of the page....
I'll keep looking!
Cheers,
Phil J
Old 07-24-2009, 09:22 AM
Big World Big World is offline
Of course you've trashed your prefs?
Doug
Old 07-24-2009, 11:41 AM
WStarnes WStarnes is offline
Hi Phil,
Did you double check Mac System Preferences/Keyboard & Mouse/Mouse....and make sure that at the bottom the "Scrolling" option is set to "Horizontal and Vertical?...Maybe it is deactivated there?
WS
Old 07-24-2009, 12:26 PM
guitar486 guitar486 is offline
Get the mighty mouse!
----I was thinking of taking a solo in the bridge.
-Nah, I don't think that would sound good.
----Ok, well how about just a series of cool riffs?
Mac Pro 2008 (Harpertown) -- OS X 10.8.2 -- 16GB RAM -- WD Black Drives -- UA Apollo Quad -- Pro Tools 10 w/ CPTK
Old 07-25-2009, 01:02 AM
s0und80y s0und80y is offline
The mighty mouse and the new mac keyboards are really awful in my opinion.
The mighty mouse would be ok if the ball was 3 times the size.
Old 07-25-2009, 01:48 AM
Originally Posted by WStarnes View Post
Hi Phil,
WS
I thought I had, but I bet that's it... I'll check first thing Mon. I love the shift/roll option... so much easier. Thanks dude.
Old 07-26-2009, 06:32 AM
Unhappy Re: hold Shift and scroll via mouse wheel? (on Mac)
Hi Phil,
WS
Actually no, that has no bearing either way...
I'll try trashing preferences, so frustrating... something so small. It doesn't really matter. I can set scrolling to continuous - I just really like using Shift > roller wheel to scroll.
Old 07-26-2009, 10:59 PM
Deleted preferences, did some other troubleshooting stuff also (including Disk Warrior), no joy. My home G5 system is totally fine.
It worked on the PT 7.4 HD 2, OS X 10.4.11 system fine, then stopped working after some other freelancers had been on the system. It's a mystery!
HTML code is On
shift key + scroll wheel = broken dkrz Pro Tools 9 4 11-21-2010 04:37 AM
SHIFT + Scroll wheel not working HELP! Dajaun Pro Tools TDM Systems (Mac) 2 09-17-2008 07:50 AM
Scroll Wheel Ratio on Mouse 25ghosts Pro Tools TDM Systems (Mac) 3 08-14-2007 12:25 AM
7.3 & Mouse Scroll Wheel Enhancements who 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-30-2007 06:49 PM
MICROSOFT MOUSE SCROLL WHEEL ALLTRIPS General Discussion 3 06-24-2003 11:42 AM
