Old 02-23-2008, 01:22 PM
PleasantNoise PleasantNoise is offline
Default XMON signal charge while quitting Pro Tools
While quitting Pro Tools or Digi CoreAudio, there is a loud spike in the speakers.
The mute on the Dcontrol does not affect the noise it can be mutted and still come through.
Selecting a diffrent input on the controller does not affect the spike either.
Can anyone help?
Old 02-24-2008, 10:33 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: XMON signal charge while quitting Pro Tools
Can you tell us a bit more about how your setup is wired ?
Are the speakers hooked up directly to the X mon or through a patch ?
Is it always the same speaker that produces the spike ?
if so ... how about for testing purpose hooking up another speaker to that same output to determine wether the problem actualy comes from the Xmo output or from the speaker.
I'm thinking the problem may also come from of your interfaces .... you could try to hook up a set of speakers directly to the interface (careful you don't send any signal through without attenuation on them).
You should be able to narrow down things first a bit to see where exactly the spikes are coming from.
A few other things :
- does this also happen when you load PT and then immediately quit without loading a session first or only after you've loaded a session.
- fwiw ... trash all PT related prefs (digisetup / PT prefs) and all digi database files on your different drives to make sure those are not the cause.
Hope you ca sort it out easily ... it shouldn't be happening that's for sure.
Chris
Chris Lambrechts
Applications Specialist- Live Sound
Old 02-25-2008, 09:26 AM
Thnx!
Will try out your suggestions and will post any results.
Thnx again.
No audio signal or midi signal after pro tools 8.04 upgrade allgenres 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-01-2010 08:58 AM
Pro Tools Keeps Quitting macfreak86 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-12-2009 05:49 AM
XMON & 192 | Signal Flow and Patch Bay b2studios ICON & C|24 18 04-11-2007 07:07 PM
Pro Tools Quitting! seifaldin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-23-2004 03:15 AM
Pro Tools keeps quitting MLK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-01-2004 06:06 PM
