Go Back   Avid Pro Audio Community > Announcements > Technical Alerts
Old 10-02-2007, 10:02 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 7.3.1cs5 Updates for All 7.3.x Systems
Pro Tools 7.3.1cs5 updates for all Pro Tools HD and native 7.3.x versions on Mac and Windows are available for download from the Pro Tools CS Updates Page under Quick Links in the Support section:
http://www.digidesign.com/index.cfm?...4&itemid=23300
In addition to previous fixes, Pro Tools 7.3.1cs5 includes the following:
ALL SYSTEMS
Pro Tools HD, LE, M-Powered, Academic - Mac & Windows
Fixed: In Some Circumstances, a Trim Edit Could Not Be Constrained (Item #94425)
- The "constrain" command (Control+Trimmer on OSX; Win+Trimmer on XP) would not work under certain editing situations involving overlap/underlap.
MAC ONLY
Pro Tools HD, LE - Mac
Fixed: Regions Could Disappear From a Session After Neo Assertion Errors (Item #97360)
- In some cases, having to force quit after getting Neo Assertion errors could cause all regions to be removed from a session.
Fixed: Intermittent Graphic Freeze When Using Pro Tools (Item #82932)
- Pro Tools would continue to play while the GUI was frozen, with intermittent plug-in automation and MIDI playback, and then unfreeze.
HD ONLY
Pro Tools HD - Mac & Windows
Fixed: Closing and Reopening Session Could Toggle The Inactive/Active State Of Some Sends (Item #97716)
- This only would occur with Delay Compensation disabled
Fixed: Send Outputs Would Intermittently Stop Routing Audio (Item #88757)
- The workaround was to shuffle paths in the I/O Setup, use another bus path, or reopen the session.
Pro Tools HD - Windows
Fixed: Using the ProControl Keypad or Channel Matrix Could Result in Double-Typing Characters (Item #97236)
- This problem was introduced in version 7.3.1cs4
Administrator
HTML code is On
Pro Tools 7.3.1cs5 Updates Avid Pro Tools M-Powered (Win) 0 10-02-2007 11:02 PM
Pro Tools 7.3.1cs5 Updates Avid Pro Tools M-Powered (Mac) 0 10-02-2007 10:59 PM
Pro Tools HD 7.1cs5 Updates Avid Pro Tools TDM Systems (Mac) 8 03-11-2006 12:19 AM
Pro Tools HD 7.1cs5 Updates Avid Post - Surround - Video 0 03-06-2006 04:43 PM
Pro Tools HD 7.1cs5 Updates Avid General 0 03-06-2006 04:42 PM
