Old 11-26-2007, 03:30 AM
Arno Peeters's Avatar
Arno Peeters Arno Peeters is offline
Default Re: Restoring DATa backups
Yes, I let the Restore-option run for at least an hour, but it keeps on saying 'Reading Header...'
All slots except for Slot 0 are greyed out. All is on version 5.1 (Digi Init, DAE).
it alternates samples to the L and R tracks. There might even be a way to fix that.
What are you thinking of?
Arno Peeters
Tape TV Productions
Old 11-27-2007, 01:43 PM
jeffro's Avatar
jeffro jeffro is offline
> I let the Restore-option run for at least an hour, but it keeps on saying 'Reading Header...' <
Sorry for a basic question here... Did you hit play on the DAT Machine after selecting Restore? DATa doesn't start the deck.
linkedin
Old 11-27-2007, 10:18 PM
Sure, I know that. Tried several times both from the ID and the start of the tape. Either the header is damaged (?) or there is some other incompatibility playing up here... I remember I took care of good quality DAT-tape and a reliable recorder back in 1996. Like you said before: what trick could I use to handle 'interleaved mono files' if present in this backup? (don't remember whether I used this option).
Arno Peeters
Tape TV Productions
Old 11-29-2007, 05:18 PM
jeffro's Avatar
Thanks, I had to ask. If it doesn't respond to the header (start restoring) then you can stop the DAT - it won't help to let it play.
If 'interleave' was off, you should be able to just transfer the audio. If 'interleaseve' was on, you could transfer the audio into a stereo app then use ResEdit to change the Channel resource from 2 to 1 which would put the samples back in the correct order in a mono file. (In either case, you'd lose the start/end points of the files and have to edit them.) Do you happen to have Sound Designer II on that computer?
linkedin
Old 11-30-2007, 01:47 AM
No SDII, lost my key-disks years ago. But I'll import the DAT into my studio-rig and I can use Soundhack to change the header, if need be.
Wouln't it be possible to just sum the L&R channels to mono?
And what about the speed? It sounds like it's 2x?
Arno Peeters
Tape TV Productions
  #16
Old 11-30-2007, 04:46 PM
jeffro's Avatar
If it sounds like it's 2x, then you probably used 'interleave' which alternates samples to the L and R tracks to speed up the backup/restore. Transferring this in as a stereo file and editing the resource might get you back in business.
I'll contact you directly to follow up...
linkedin
HTML code is On
Restoring your "Preview"? uno1234 ICON & C|24 2 04-23-2008 12:47 PM
Restoring Tracks, Please Help. ves1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-28-2007 10:18 AM
restoring old files viaspiaggia Pro Tools TDM Systems (Mac) 1 06-06-2007 09:45 AM
Restoring DATa backups plutone Pro Tools TDM Systems (Mac) 4 01-26-2006 08:34 PM
Restoring DATa to mix hardware?? dave-G Pro Tools TDM Systems (Mac) 7 05-07-2002 06:34 PM
