Old 04-12-2012, 04:54 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Default Low Latency Monitoring and Hardware Inserts
I'm having some strange behaviour with hardware inserts and LLM.
If I have a track sending to the LLM nominated outs (1-2 in this case), and I use a hardware insert, the track no longer passes through my 1-2 master track plugins (L2007 in this case), if I make the harware insert inactive, the track is now effected by the master track plugins. (The mentioned track is not in record either).
I checked the manual, but couldn't find this specific situation noted.
Can anyone else recreate this?
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 04-12-2012, 07:43 PM
cananball cananball is offline
Default Re: Low Latency Monitoring and Hardware Inserts
LLM disables plugins. This is normal behavior AFAIK
Ken Wilkinson
http://kenwilkinson.tv
Pro Tools 10.3.9 HDN | HD Omni | Digi Command 8 | Artist Transport | Digi Surround Panner | Blackmagic Intensity Pro | JBL LSR4328 5.1
2.26GHz 8 Core Nehelam 8GB Ram OSX 10.8.5
Old 04-12-2012, 08:51 PM
Only if you're in record. This is disabling the master section when not in record.
Old 04-13-2012, 05:03 PM
No-one? Avid?
I'm actally finding LLM so hard to work with, its almost useless.
I turned it on in an old session the other day, and it muted the bass. It wasn't a well played bass, but it should be my call to mute it, not the programs.
Restart tha Mac, and it came good again.
Old 04-13-2012, 07:20 PM
danander11 danander11 is offline
The bass playing or the audio?
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 04-13-2012, 08:32 PM
necjamc necjamc is offline
That gave me a good laugh.
Old 04-14-2012, 12:48 AM
Nice
I wonder how an artist would feel if you said.."That take was so bad I need to reboot."
Old 04-15-2012, 04:51 PM
Bump...Still wondering about this one.
Old 06-18-2012, 07:31 AM
mu-tron-kid mu-tron-kid is offline
Location: Ithaca College School Of Music, Theatre, and Dance
One of my Colleagues just experienced this same error on a PT 8 LE with 002 rig.
Toggling LLM off seems to have solved it, but yes, with a couple of Hardware inserts, the audio was not passing to the Bounce...
Additionally, RTAS plug-ins placed AFTER the Hardware Insert were not having any audible effect...
No Tracks Record Enabled.
Brian Dozoretz
ACSR
ACI Dolby Atmos
Mac Pro, os12.6.3, PT 22.12 HDX, 2xAlphalink,1xDeltaLink,
Mac Mini, os12.6.3, PT 22.12 HD Native + HD Omni, Artist Series Mix x 2, Artist Series MC Transport, Atmos 5.1.4
VENUE SC48 3.2 with iPad Control
SSL Duality
SSL Duality via ipMIDI / ∂elta Automation Plug-In
Old 06-21-2012, 08:08 AM
LLM will disable inserts AND sends. If you want to record thru hardware, its best done before conversion. You CAN do it by turning LLM off and running at a low buffer, but you will suffer the latency from the extra chain of conversion(out to the hardware and back in).
Latency Compensation on Hardware Inserts BJosephs macOS 6 07-11-2011 06:45 AM
Third party hardware and Low Latency Monitoring The Dougfather Pro Tools 9 3 11-05-2010 07:03 PM
latency when using hardware inserts (oo3) earmeter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-14-2008 06:38 PM
[002R] Hardware Inserts Latency: how much is it? HotRats_Reloded 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-14-2006 01:03 PM
latency on hardware inserts vtone Tips & Tricks 4 10-22-2000 05:37 AM
