What do i import a "dual mono" audio file as??? mono or split stereo?
i have questions about this.....
it's a very nice dual mono sample that travels from left to right. a big analog synth piece. 1. import as mono or stereo? and 2. where do i pan it in the mix? 3. any additional comments on your experience with this....... [img]images/icons/smile.gif[/img] |
Re: What do i import a "dual mono" audio file as??? mono or split stereo?
Name the 2 samplefiles something like "sample.L" and Sample.R". Now protools will recocgnize them as a "split-stereo" and load it on a stereo-track, and treat it as stereo. If you leave all the panning knobs alone on a stereo-track, everything is panned hard left/right. If you decide to load them on 2 seperate mono-tracks, you should pan each channel accordingly, as a mono-channel defaults in the middle...
What's that? - That's the machine that goes "pling". Bastiaan |
"Dual Mono" = two tracks that are identical (ie. 2 x mono) "Sample That Travels From Left To Right" = Stereo That being the case, import as stereo - if you want to preserve the left to right motion. Or as Bastiaan assumed, does the stereo sample exist as two separate files, (ie.Left and Right)? In which case, follow his good instructions. Phil
SoundPunk | Pro Tools Tips & Tricks |
i think i understand.
here is a better explaination. the "dual mono" synth tracks have one sound on the right side, and a slightly different sound on the left side. and the sound travels back and forth , right to left.....when played together. so i will import the right side as a mono track, and pan mid right. and the left side as another mono track and pan mid left. this way i am actually recreating the stereo effect that happens when these dual mono tracks are combined. this is a good way to do it right? * can one have a whole song of nothing but carefully panned mono tracks?? doubled where needed, etc.... i can actually create stronger sounding stereo tracks this way, right? [img]images/icons/smile.gif[/img] |
Mind you, doing it this way (ie. across two tracks) is clumsy when it comes to editing and effects placement. The better way is as Bastiaan pointed out: "Name the 2 samplefiles something like "sample.L" and Sample.R". Now protools will recocgnize them as a "split-stereo" and load it on a stereo-track, and treat it as stereo." This way, you can edit, arrange, and process the two files in Pro Tools as if they're a single entity. Quote:
Except in cases where a synth might use separate layers panned opposite from each other that I want to preserve, I record all my synths and electronic percussion in mono. Why waste two tracks when one will do perfectly? Particularly as we only have 24* of the darn things! Phil *24 tracks to be increased to 32 tracks by July 31st 2002 as per Digidesign's announcement. (Fingers' crossed) [img]images/icons/cool.gif[/img]
thanks!! i feel smarter.
to further ellaborate on stereo files....... you said to treat them like stereo files.......how exactly do i treat stereo files? i dont have muc experience with them. is it true that if you have 2 stereo tracks panned dead center the sound is weakened or masked? where with mono you can have limitless on top of eachother and it won't weaken the sound. so how should i pan stereo tracks? i will probably have 2 - 3 stereo tracks among the rest of the mono tracks. (basically for the electronic trancey synth lines) like this synth track for instance? if i do it as split stereo, where should it be panned to get the R to L traveling effects to shine... if i pan it anything other than dead center one of the sides will be louder right? so i guess the old mono method would be better......like i mentioned earlier. [img]images/icons/smile.gif[/img] |
Stereo tracks are just two mono tracks put together. THere is absolutely no difference between two mono tracks and one stereo track.
Stero IS two mono tracks. When you make a stereo track ..it is just two mono tracks attached to one fader. IF you want the two mono tracks to be true stereo, Hard pan them. When you make a stereo track, it defaults to hard panning. It is very simple. No need to wig out. |
i can make 420 pipes out of apples.
He used to cut the grass...he was a very nice boy... |
Consolidate vs Duplicate - "Stereo" vs. Dual Mono Behaviour | rnd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-05-2013 01:03 AM |
What are the difference between using a "mono" vs "mono/stereo" plug in on mono track | rockguitarist1255 | Pro Tools 10 | 4 | 12-07-2012 08:07 AM |
2 mono split - to 1 stereo file | rinky | Pro Tools TDM Systems (Mac) | 3 | 06-28-2006 04:18 PM |
Mono, but no "Beatle Stereo" | Moses Presley | Tips & Tricks | 18 | 09-22-2003 02:51 PM |
HOW can you import a "stereo" WAV. file into PT as a "mono" file? | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-21-2002 09:14 PM |
