Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 01-24-2021, 04:06 PM
BLG BLG is offline
Default No sound from midi drums
Hi. I created an instrument track, added the XPand!2 plugin, selected Rock kit as the preset, went back to my track and opened the Midi editor and when I click on key 0 I hear nothing. My track has no input and Output 1-2. My collaboration partner sees movement on the audio meter but hears no sound. I don't even see the meter move. I've tried to add notes and initially couldn't do that but now I'm able to by double-clicking in the track area of the Midi editor but again no sound.
I should add that I'm running Windows 10 and he's running on a Mac. We collaborate via the Avid cloud.
What am I missing?
Old 01-24-2021, 07:06 PM
Default Re: No sound from midi drums
"opened the Midi editor and when I click on key 0"
What do you mean by "key 0"? If you are referring to keys on the QWERTY keyboard, that doesn't work(without a special utility to give the keys a midi note assignment, which is bad in PT because PT uses pretty much every key). The solution for this would be to add a midi controller or pad device
Also, if your goal is drum tracks that sound like a real drummer on a real kit, you will grow tired of Expand really soon. Take a look at Toontrack EZDrummer2, Superior Drummer 3, or XLN Addictive Drums2. Those are 3 of several drum VI plugins that can make really good drum recordings via midi
Old 01-25-2021, 07:51 AM
Philthy Philthy is offline
What am I missing?
Did you record arm the drum track? Are you trying to play using the little MIDI keyboard on the screen? Are you sure there's a sample on MIDI 0?
Phil Mann
Silk City Music Factory - CT Recording Studio
Old 01-25-2021, 08:34 AM
BLG BLG is offline
By Key 0 I mean the 0 key on the virtual keypad (the piano bar). Not the actual computer keyboard.
No - I didn't record-arm the drum track but I've never had to do that before. And I'm pretty sure there's a sound on key 0 - that's where the kick drum has always been.
Also the "Key 0" sometimes highlights when I hover over it and sometimes it doesn't. Sometimes the highlight seems to get stuck on one of the keys and clicking other keys doesn't change that. I've tried clicking on multiple keys BTW - not just 0.
As for XPand!2, this is just for a scratch drum track that will later be replaced by a live drummer track so I don't much care about the sound.
Old 01-25-2021, 11:03 AM
Are you getting sounds from other tracks? For example, from an audio track?
Phil Mann
Old 01-25-2021, 11:46 AM
cwsand's Avatar
cwsand cwsand is offline
And what is your selected output path for the Instrument track?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 01-25-2021, 05:36 PM
BLG BLG is offline
Yes there is sound on all of the other tracks. And the output path is Out 1-2 (or something like that). Same as all of the other tracks that are working.
Old 01-25-2021, 06:34 PM
The tiny keyboard in the plugin can't actually record(its just to audition notes and sounds). Best to get a midi keyboard, but in the meantime, you can drop notes on the piano roll with the mouse(using the SMART tool or the Pencil tool). Just set your INSTRUMENT track view to NOTES first.
Old 01-26-2021, 08:51 AM
BLG BLG is offline
Thanks Dave, but that's exactly what I'm doing.
TD-30 and Addictive Drums 2: MIDI notes triggering incorrect sound dcristof Tips & Tricks 3 07-23-2020 11:51 AM
Problem: Recording Electric Drums via Midi with Addictive Drums (Latency problem) Don Bravo General Discussion 5 07-04-2014 11:49 PM
Adding MIDI drums to acoustic drums - Velocity Pat.m Pro Tools 11 5 11-01-2013 08:40 PM
Creating midi drums that sound like real ones Anduril 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-13-2005 07:44 AM
Midi drums on Sound Canvas bruk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-16-2004 12:54 PM
