Old 08-12-2012, 03:25 PM
Hanswurstlsepp Hanswurstlsepp is offline
Default MacPro4,1 optical out -> Avid HD I/0 not working
I'm trying to connect the optical S/PDIF (Toslink) output of my MacPro to an Avid HD I/O. I wanted to use the enclosed HD I/O's optical ADAT input.
Unfortunately I'm getting no audio signal at all. Not even a crackling occurs.
I also tried with the optical inputs of my 192 Digital interface and with my ProFireLightbridge which is connected to my MBP.
The ProFireLightbridge produced at least some crackling ... but still no audio.
I googled a bit and found out that for some people it's working and for some people not.
Are there any specific options/settings I could try ?
Additional info:
All my 4 Avid/Digidesign interfaces are clocked by a BigBen.
Also one PC (using RME Multiface HW - routed back via Lightpipe to a 96 I/O), another PC and the ProFireLightbridge (routed back via Lightpipe to 192 Digital I/0) and my Roland vSynth GT (clocked via SPDIF from BigBen and routed back via SPDIF to the 192Digital I/O).
Everything works fine except the Mac's optical out
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 08-12-2012, 06:44 PM
Tweakhead Tweakhead is offline
Default Re: MacPro4,1 optical out -> Avid HD I/0 not working
Originally Posted by Hanswurstlsepp View Post
snip ... I'm trying to connect the optical S/PDIF (Toslink) output of my MacPro to an Avid HD I/O. I wanted to use the enclosed HD I/O's optical ADAT input.
ADAT Optical and SPDIF Optical are not the same thing. Are you plugged into the correct one? and did you configure the correct one in your Hardware & IO Setup?
http://www.avid.com/Static/Resources...al_enlarge.jpg
From the manual:
"Note that Optical S/PDIF is not supported with the Digital I/O card and is supported with the enclosed Optical ports only (for more information, see “Optical (ADAT) [Encl]” on page 10)."
Old 08-13-2012, 08:46 AM
From the manual:
Hi Tweakhead,
you're my man - thank you so much !!!!
I double checked that I'm using the enclosed optical input od the Avid HD I/O and now it works great ! So it seems like, that I used the wrong optical in
Cheers, STeff
Old 08-13-2012, 01:15 PM
Good news. Happy to help. Thanks for reporting back, as it helps other people in the future.
Digi 002 - optical input not working / only DI channel 1 working Maulden7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 11-07-2013 01:46 AM
Optical Not Working After Upgrading to 10 brtmix Pro Tools 10 1 11-18-2012 03:04 AM
Optical Out Not Working dwdrmmr13 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-10-2007 11:31 PM
G5 optical digital output - working anyone? maxx Pro Tools TDM Systems (Mac) 3 08-31-2004 10:55 PM
ADAT Optical on DIGI 001 Not Working SpillingSounds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-06-2003 07:09 AM
