Izotope Ozone
I'm playing around with the demo of Ozone, and so far I really like what I hear. What do you guys think? Greetings from a baking hot Stockholm... /Fredrik |
Re: Izotope Ozone
i like it too. very flexible and powerful. i've seen posts where the quality of the limiter is questioned but i don't hear it. i've A/B'ed with the L3 and it seemed very similar. the company is very responsive as well.
Re: Izotope Ozone
if i had to pick one tool for self mastering Ozone would be it..
"Any experiment of interest in life will be carried out at your own expense." |
Re: Izotope Ozone
Dean |
Re: Izotope Ozone
then don't record shakers!!
in my tests against the L3, on my projects, i've found it to be a good tool. |
Re: Izotope Ozone
I find it great a tool, the eq match is a nice feature! overall, not really a stereo mix bus thing! more suitable for post mastering!! ditched L2 and maxim, haven't tried L3. They have a fully operating demo version isotope.com Chris
Re: Izotope Ozone
since this is a RTAS only plug is it true you cannot use it on a Master Fader? If so it is useless for mastering.
Re: Izotope Ozone
This is HTDM and you can use it on a master fader! it does use a lot of processing power and being HTDM it will give you no indication of how much cpu it is using ( as so with all HTDM) It works great on a master fader just its more suitable for post mastering!! P.S. Don't use it as multi mono plugin! it doesn't like it! make sure you use multi-channel. Regards Chris
Re: Izotope Ozone
People are always looking for that all-in-one magic solution to make their project sound amazing. Tools like this are only a cheap imatation of the real thing & should for the most part be avoided. Having tried the Ozone demo some time ago, I found that while it did have some useful features e.g. dc removal, decent dithering options etc. for the main aspects of mastering it really didn't cut it. The EQ, Compression, Limiting & analog simulation is really only suitable for demo release material.
Mastering is one area of production that can't be faked convincingly using cheap software or hardware. Attempting to master your own mixes is not an ideal solution for many reasons. In fact in most cases these sorts of all-in-one tools often do more harm then good, even in the hands of an experienced operator. I would suggest that if you need to master something yourself due to budget restraints, that you at least look at buying separate plug-ins that are capable of doing the job more effectively. There are some good plugin options available albeit a little more expensive then the all-in-one solutions... Matt |
Re: Izotope Ozone
I don't think anyone was suggesting for one minute that this is a replacement for a professional mastering house! like yourself!? No more than Reason would be a replacement for a professional pro tools HD accel recording studio! like myself!? But it does give a great all round package for those who can't afford to, and those who wish not to, to be able to do a competent job for very little expense. Your right, there are some other great plugins available that do a better job of the individual processes, but this gives you them all together in one easy to use plug, and the results can be very good in the hands of the right pilot!! yes i may be "faking it" as you put it, as this is a plugin for $400 and not a $100000 mastering house! but my clients are more than happy with the results and keep coming back. Ozone users aren't really your customers? so how about sharing your knowlwdge and giving some mastering advise to us rec engineers Regards Chris
Izotope Ozone 3.09 | New Hope Media | Pro Tools TDM Systems (Win) | 1 | 07-22-2006 01:16 PM |
Izotope Ozone 3.09 | New Hope Media | Pro Tools TDM Systems (Mac) | 0 | 07-22-2006 08:07 AM |
iZotope Ozone 3... | cwhite771 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-05-2005 10:57 AM |
iZotope’s Ozone 3 | darkglass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-20-2005 05:22 AM |
