Old 05-18-2001, 05:10 PM
accession accession is offline
Default Re: Multiple MIDI interfaces with PTLE...
I'm running 8 MIDI devices distributed across a Roland S-MPU64 4x4 USB MIDI Interface and the Digi001. No glitches/dropouts.
On a Mac, both the S-MPU64 and the Digi001 appear in OMS. However, I'm unfamilliar with how Pro Tools distributes MIDI on a PC.
The only problems I've encountered is irregular timing when the CPU is under heavy loading with 'hundreds' of plug-ins, although I've still more experiments to do with PTle 5.1. In fact, this may be a USB or OMS issue. Disable effects, or Low Latency Monitoring and problem is fixed.
Phil
Old 05-19-2001, 12:39 AM
jbr jbr is offline
Default Multiple MIDI interfaces with PTLE...
Here's a thought...
How about using 2 MIDI interfaces.(DIGI 001 box MIDI I/O excluded)
...First for the 3 motormixes (serial)
...Second for keys and modules (usb)
If I purchase the Digi 001, I will be using 3 motormixes, 3 MIDI input devices and 5 MIDI sound modules.
The question is...would using separate MIDI interfaces solve any timing problems that might occur during a session? Also, would Protools LE recognize both interfaces simultaneously?
jbr
Multiple Midi controllers on PTLE Lizardpoint 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-31-2005 03:44 AM
Multiple interfaces on a Mac nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-14-2005 09:23 PM
Multiple Digidesign Midi I/O Interfaces? Cipher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-21-2004 01:46 PM
PTLE - MIDI Interfaces petter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-26-2002 01:14 PM
Multiple MIDI interfaces with PTLE... jbr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-22-2001 12:52 AM
