Old 11-22-2002, 04:43 AM
Sageryd Sageryd is offline
Default Have I got compatibility problems? HELP!
i want to buy the digi 001 with Pro Tools LE included.
and now i found out that my mother board is from SiS (I think). to be exact its said in the description its a MD-5000 M-ATX mainboard based on SiS 648 northbridge and 963 southbridge chipsets.
Here's all the exact details you'll need to tell me if it works with digi001 or not I hope:
Thank you for purchasing the MD-5000 M-ATX mainboard. The MD-5000 mainboard is based on SiS 648 North Bridge & 963 South bridge chipsets fpr optimal system efficiency.
CPU
>Supports Sockets 478 for P4/Celeron processors (Willimate and Northwood core) with 400/533 MHz
>Core frequency from 1.3 GHz to 2.8 GHZ and up
CHIPSET
>SiS 648 chipset
-Supports Intel Pentium 4 processors with data transfer rate up to 533MHz
-Supports 64-bit high performance DDR333+/DDR333/DDR266 memory controller
-Supports AGP 8X/4X interface
-Supports bi-directional 16-bit data bus with 1 GHz bandwodth MuTIOL
>Sis 963 chipset
-Supports Dual-IDE ATA 66/100/133
-Integrated audio controller with AC97 interface
-Low pin count interface for SIO
-Advanced power managment and PC2001 compliance
SLOTS
>One AGP (Accelerated Graphics Port) 4x/8x slot.
>Three 32-bit PCI bus slots (supports 3.3v/5v PCI bus interface).
ON-BOARD IDE
>Dual-IDE controller integrated in SiS 963 chipset
>Supports PIO, Bus Master and Ultra DMA133/100/66/33 operation modes
>Can connect up to four IDE devices.
ONBOARD IEEE1394
>Integrated in SiS 963 SB
>AGREEFW803
AUDIO
>S/W RealTek ALC650 6-Channel audio codec with SPDIF in/out
THANKS YOU!
Old 11-22-2002, 05:49 AM
Bastiaan Bastiaan is offline
Default Re: Have I got compatibility problems? HELP!
http://www.digidesign.com/compato/
sis is not supported.....
What's that?
- That's the machine that goes "pling".
Bastiaan
Intel to PPC Compatibility Problems bardace Pro Tools TDM Systems (Mac) 2 02-13-2009 03:12 PM
Compatibility Problems ... P4 Digital_G2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-30-2005 05:14 PM
File compatibility problems sadrummer1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-16-2005 04:41 PM
P4 3.4Ghz compatibility problems! pete66 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 39 01-26-2005 10:06 PM
Compatibility Problems thickcricket 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-10-2004 04:55 PM
