96io optical n/a [solved]
When I started PT today, none of my outputs routed to the optical I/O on my 96io were available. In the io setup any bus routed to anything going to optical I/O is labeled "digilink n/a" and in the HW setup all the optical I/O is labeled "optical n/a" Is my 96io dead? Anyone else ever had the same problem? Best, Espen
IMDB |
Re: 96io optical n/a
Are you set to 96k?
Need more info here. Beside the sample rate(because the optical is only good for 44.1 and 48K), what exact version of Pro Tools HD(Starting at 12.6, you need to also have a Digilink asset on your iLok). Then, what hardware is connected via lightpipe?
I was going to go thru the process of seeing if the 96IO pthd would work in PT12hd.... It sounds like you have having success. Can you tell me your config/hardware and how its been going? Ill be doing mac pro 2012 pt12hd, 96IO (at least thats what id like to work) Iv been running pt11hd with the 96IO without any problems. thanks for any thots bradp
thanks, brad Mac Pro: PT 11.3.2 HD native, MIDI IO, 96IO Mac Pro Desktop 4,1 osx 10.11.6., 8 Core 2.26GHz 2009 Intel Xeon MB535LL/A 16GB RAM 640GB HD ATI 4870 ----- MBP: OS 10.11.6, MacBookPro 5,1, Intel Core 2 Duo 2.4GHz Memory: 8 GB Bus Speed:1.07 GHz, Boot ROM Version: MBP51.007E.B06, SMC Version (system):1.33f8 |
Digi 96io - can you mix Optical SPDIF and phono SPDIF? | buckaroo | Pro Tools TDM Systems (Mac) | 1 | 08-24-2009 11:20 AM |
Clock Issue on 192 i/o Optical [ADAT] Not Optical [Encl] | Willard | Pro Tools TDM Systems (Mac) | 1 | 10-10-2007 01:23 PM |
ADAT optical vs TOSLINK optical (vs COAX) | cc1 | Pro Tools TDM Systems (Mac) | 4 | 06-15-2004 06:02 AM |
192 : MUST select Optical format for Bay 3 to activate Enclosure Optical inputs????? | el biciclista | Pro Tools TDM Systems (Mac) | 2 | 07-09-2002 10:32 AM |
whats the difference between adat optical and spdif optical? | Vegadark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-07-2002 07:42 PM |
