Old 03-13-2012, 05:59 AM
meyoik meyoik is offline
Default No elastic audio regions selected
Why is PT giving me this error message:
"no elastic audio regions selected"
when trying to use elastic audio?
I have enabled it on the track, selected Polyphonic, I now select the region with the grabber tool so that it is highlighted, I then right click the selected region....and I get: "no elastic audio regions selected"
WTF?
Old 03-13-2012, 08:10 AM
Default Re: No elastic audio regions selected
N-o-b-o-d-y in this forum knows why we get that error message!?!??
Old 03-13-2012, 10:13 AM
Still nobody.....?
OK this is what I have found so far....
If you have 2 regions, and then you group them...it seems that you will not be able to use elastic audio on those regions.
Is that familiar to anybody here...perhaps?
Old 01-28-2014, 11:09 AM
Paul Sombric's Avatar
Paul Sombric Paul Sombric is offline
Hey! I came to the same problem also. What I did was instead of using the elastic properties, I used the time shift plugin (attachment shows where to get it). Hope that helps!
File Type: jpg Screen Shot 2014-01-28 at 2.07.26 PM.jpg (60.3 KB, 0 views)
Old 01-29-2014, 04:07 AM
Originally Posted by meyoik View Post
Still nobody.....?
EA has never worked on clip-groups, AFAIK. I think it's mentioned in the manual.
Old 04-13-2020, 09:17 AM
yannou78 yannou78 is offline
I had the same problem and I just found out how to make it work..... you have to select the WHOLE track then press ALT+5 (number pad)
HTML code is On
Elastic Audio not rendering ALL REGIONS Kourquie Pro Tools TDM Systems (Mac) 1 10-04-2010 10:26 AM
Moving elastic audio regions getting quits!! crizdee Pro Tools TDM Systems (Mac) 0 12-08-2009 12:45 PM
Elastic audio regions fariksungod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-09-2009 09:16 AM
Elastic audio mangled the end of all of my regions??? The Dougfather 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-08-2008 12:00 PM
Cllearing selected audio regions surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-27-2001 11:54 PM
