so much for fewer restarts with OS X...
Using HD 2, G4 450 dp, OS 10.2.6, PT 6.1
I work for hours using reason and protools with rewire. no trouble, then go take a shower or have a meal. When I return, protools doesn't work. When I have the cursor over PT, I get the dreaded spinning beach ball. This last time I wanted to really see what it took to get going again. I was told "with os x, protools can't bring the whole rig down. You just force quit and restart. Well, after waiting for 5 minutes of the colorball, I did force quit PT. and reason, it ws hung too. Then I tried to restart PT. The first message was a -4 error, then it said "could not complete your request because midi string...." or something like that, at which point PT quits again. I tried the various stages of resetting things, to see if anything short of a restart would work. First I trashed the dae and digi prefs, tossed the trashg and tried to launch pt again. Same error messages. Next I trashed PT prefs and tried again. Same thing. Next I relaunched the finder. No help either. Finaly, I logged out and back in. Still got the same error. After a restart, everything is fine. Oh well. Hope springs eternal. Peace. Thanks for trying digi. |
Re: so much for fewer restarts with OS X...
Check in the System Preferences to see if your machine is set to sleep automatically.
I was surprised to see in the Read Me for PT 6.1 that Digi says it is necessary to restart the computer when there is a force quit or a unexpected quit. I too was told the great thing about OS X is that after a crash you don't have to restart the whole rig. I have in fact had unexpected quits and successfully reopened PT with out restarting.
I can only imagine that the connection to TDM hardware can get messed up in a force quit so a restart is required. I guess that makes sense. But it is a bummer. P.S. Also after any force quit/restart it's probably a good idea to go to disk utility and "repair permissions." Note: Oops...This isn't what I meant, I corrected this statement below... |
So should I set the energy saver to never sleep? It is set to sleep after one hour. Can' t protools survive a wake up? |
You're right--I should have said after you have a few sudden quits or force quits causing you to restart a bunch of times you should do the repair the permissions. I definitely don't do it after every force quit.
ProTools does not support the Energy Saver. You might want to check out the Read Me file for 6.1 update. There's a huge list of "known issues." The Energy Saver issue is one of the big ones. |
So should I set the energy saver to never sleep? It is set to sleep after one hour. Can' t protools survive a wake up? [/QB]<hr /></blockquote><font size="2" face="Verdana, Arial">No, there's no need to repair permissions after a force restart, but it is recommended that you run fsck -y from single user mode. It's Apple's disk utility. The same one that comes up in OS 9 after a crash. And yes, sleep is your problem. Set the machine to never sleep. Even putting the machine to sleep with PT open in OS 9 will cause a crash. G4's with PCI cards installed have always had issues with sleep, no matter what OS you use. Did you see the OS X hint's Digi put at the top of the page? In System Preferences > Energy Saver Uncheck anything that allows the computer to go to sleep/shutdown/ power save etc. |
Energy Saver settings are the second item on the OS X requirements page on the website:
http://www.digidesign.com/compato/osx/os.cfm and item number 4 under "Installing Pro Tools 6.1 on Macintosh" in your "Upgrading to Pro Tools 6.1" document.
Administrator Avid Pro Audio Community |
oh jeez. ok ok i promise to read the docs from now on
oh jeez. ok ok i promise to read the docs from now on oh jeez. ok ok i promise to read the docs from now on oh jeez. ok ok i promise to read the docs from now on oh jeez. ok ok i promise to read the docs from now on oh jeez. ok ok i promise to read the docs from now on oh jeez. ok ok i promise to read the docs from now on oh jeez. ok ok i promise to read the docs from now on oh jeez. ok ok i promise to read the docs from now on Thanks for clearing this up everyone! |
You were supposed to write that 10 times...you missed one. I suggest you write it over... [img]images/icons/wink.gif[/img]
soundphaRm |
Running fsck -y without CD:
Reboot, after the starup sound press and hold "command and s" (boots into single user mode) type "fsck -y" press RETURN try again if errors are found, repeat until all clear. type "reboot" press RETURN done. |
Why does Pro Tools perform better when it is using fewer cores? | meech | macOS | 12 | 03-19-2013 03:03 PM |
Can Mix Window Display Fewer Insert and Send Slots? | taylor4814 | Pro Tools 9 | 4 | 09-30-2011 05:21 PM |
Using Stems for better mixes Less math =fewer audible errors | sonicboost | Tips & Tricks | 20 | 07-10-2008 08:30 AM |
Errors and restarts with PT7 | soundfx | Pro Tools TDM Systems (Mac) | 1 | 02-22-2006 11:30 AM |
PT 6.4 Restarts my Machine | Producers Never Sleep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-12-2006 07:24 PM |
