PT 7.4 cs3 - Text Input stops working
OS X 10.4.11
Mac G5 Dual 2.7 - 6GB Ram PT version 7.4cs3 Since upgrading from 7.3 to 7.4cs3, after a breif period of time, Text input becomes completely disabled. I cannot name or enter values in any text fields. This is true for track naming, Plug-in naming, and session naming via the save dialogue. No other applications are effected, this is a pro tools issue. But, I can still use key commands. Save, switch windows etc etc, all key commands are working. But any field with a dialogue for entering text does not work. If I quit pro tools, and re-open. I get the ability to type text back for a brief time, and then randomly it becomes disabled again. anyone else see this? bd
_b. |
Re: PT 7.4 cs3 - Text Input stops working
I experienced this for the first time ever, shortly after upgrading to 10.4.11 and Pro Tools is not installed on this particular Mac.
Textedit was/is okay, just could not rename folders and the like I have Pro Tools on another machine 10.4.9 and did not experience it on that machine. For me it is a bug in 10.4.11 that comes and goes, although not recently since regular maintenance. It may not be related to your situation but as you are on 10.4.11 i thought i would mention it. |
This bug has been around for over 2 years. There are numerous threads for it, and basically Digidesign says they can't really reproduce it.
I have found it happens more often when you open and close different sessions from within the same folder. But it's not really repeatable, and has actually disappeared from my system for the last few months. |
This has been on ongoing investigation and we've turned up some info recently that points to an OS issue - or at least something that would indicate why we are having difficulty determining the source of the problem. There are many reports of this happening in other applications besides Pro Tools:
http://overstated.net/2005/03/23/os-...-locking-issue http://discussions.apple.com/thread....98977&tstart=0 http://cssbeauty.com/skillshare/discussion/1487/ We are continuing to investigate this and have logged a report with Apple for an investigation on their end. |
Despite this "problem" being around for two years, I NEVER had it until I bought the Waves Mercury Bundle. Then, I had it on a regular basis. But now it is gone. Two changes: Upgrading PT7.4cs2 to cs3, and upgrading Waves to 5.9.7 when it came out. Both happened at about the same time. I can't say if either or both did it, but it is gone.
BTW, I have two systems (G5 dual 2.7's, OSX 10.4.9, HD3), and the problems came and went on both machines at the same time. Personally, I think it was Waves. |
Softsynth stops working | Dave Modisette | Pro Tools 11 | 8 | 02-16-2014 09:58 AM |
No Text Input PT 7.3.1 (Mac OS X) | Nello7 | Pro Tools TDM Systems (Mac) | 1 | 11-10-2008 07:06 PM |
002 randomly stops working!! | reyalp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-24-2006 06:12 PM |
7.2 -- what stops working? | brucecoughlin | Pro Tools TDM Systems (Mac) | 2 | 08-29-2006 12:05 PM |
bussing stops working | babyseal | Pro Tools TDM Systems (Mac) | 1 | 08-14-2002 01:15 AM |
