Old 03-31-2009, 12:34 AM
the 5cientist the 5cientist is offline
Default Digi 002 M-Audio Octane ADAT clock problem!
Hey guys,
I'm a real novice at this stuff, but I got a small little setup, of an M-Audio Octane Pre into my 002 Console.
I got real excited at the prospect of using ADAT to connect the 2 units, so i got my lightpipe cable, and went to record.
I started to get clicks and pops out of the ADAT, and i've since realised that this is a problem with the clock between the 2 units. (still trying to work out what the clock is but anyway...)
When i get to Setups>Hardware Setup... To sync the 002 clock with the OCTANE, in ProTools 6.4 I get the message that 'There are no Digidesign Cards in the System'. I can't work out what that means, or any other way around it?
How do i sync the clocks so that i can use my mic pre?
Thankyou so much for anyhelp you can give!
Will
http://www.willudall.com
Old 03-31-2009, 06:09 AM
Third Eye Studios Third Eye Studios is offline
Default Re: Digi 002 M-Audio Octane ADAT clock problem!
Set the clock on the 002 to ADAT. Make sure your session and adat preamp are set to the same sample rate.
Old 03-31-2009, 08:32 PM
Thanks Third Eye, but the only way that i can find to set the clock on the 002, is in the Setups>Hardware. HOWEVER, as mentioned in my original post, and highlighted below, Hardware Setup is blocked for me, with an error message:
How can i get around this error, to then be able to set the clock to ADAT?
Thanks,
Will
work clock sync 003/RME Fireface/M-AUDIO octane b mcgibney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-08-2008 11:29 PM
Newbie: Get no signal from M-Audio Octane via ADAT Braveheart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-17-2008 09:06 PM
Digi 002 R problem detected with audio clock. HELP :( thexflamesxburn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 06-11-2007 11:10 AM
problem detected with audio clock Digi 002 rack Ben83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-13-2006 10:35 PM
M-audio Octane, and ADAT (toslink?) w/CoreAudio KamaSutra77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-22-2005 10:59 AM
