Option trim and nugdge command
By using the option key (windows key on 98/XP), and having a region selected, you can use the nudge values to slip the beginning of the region edit back and forth. Is there a way to move it to the left, and have it snap against the left most region, in a way that the trimmer tool, in conjunction with the option key(windows key), and dragging it to the left does? Thanks.
Best regards, Siegfried Meier |
Re: Option trim and nugdge command
I think what you're asking will get accomplished with CTRL-SHIFT-TAB, but It's a little unclear, so I'm not sure. Try that, and let us know if that's not what you're going for.
-Olaf |
Option/preference for disabling Loop Trim? | Morrisound | Pro Tools TDM Systems (Mac) | 1 | 01-31-2007 11:54 AM |
Does PT has a trim fader option? | macrocklin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 07-25-2003 12:13 AM |
Option Trim back using Nudge | Siegfried Meier | Pro Tools TDM Systems (Mac) | 0 | 05-30-2003 08:10 AM |
Command-Trim in PT6 | jdhiler | Pro Tools TDM Systems (Mac) | 0 | 02-27-2003 12:42 AM |
Command-Trim in PT6LE | jdhiler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-26-2003 02:53 AM |
