Old 03-19-2015, 06:36 AM
jigdagod jigdagod is offline
Default Avid Artist Mix Diode
Anyone good with circuit boards know what type of diode this is? I knocked one off when I was putting on the new faceplate. I seen about 12 different ones that look like this. I don't want to send it for repair. It goes to one of the channel select button and now when I test it that one doesn't work.
https://www.westfloridacomponents.co...untDiodes.html
Old 03-20-2015, 12:22 PM
MoPro's Avatar
MoPro MoPro is offline
Default Re: Avid Artist Mix Diode
Originally Posted by jigdagod View Post
I knocked one off when I was putting on the new faceplate... I don't want to send it for repair.
First off... If you have indeed knocked that surface mount diode (SMD) off the circuit board (PCB), you may still need to send it in for repair, as you may have also torn or raised the land off of the PCB.
If you have just knocked the component (SMD) off and the lands are intact (unlikely)... then you could just re-solder the old SMD back on the PCB as there is no reason to believe the component itself is damaged, but you should test it to be sure!
If you don't know how to do any of this... you should send it in for repair, because you may have more damage than you recognize, and the authorized repair center will have a proper testing facility!
Good Luck!
Al
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black
Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit)
Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3
Old 03-27-2015, 05:48 PM
I found the right diode, installed it and its back to working again.
http://www.digikey.com/product-detai...TR3-ND/4827414
This the ebay user that helped me figure out which diode it was and the item.
http://pages.ebay.com/link/?nav=item...631193&alt=web
Old 03-28-2015, 05:13 PM
MoPro's Avatar
Great news!
Avid artist mix!! help please baybadness Artist Series 3 09-14-2014 03:37 AM
FS: Avid Artist Mix Chingy Buy & Sell 1 02-19-2014 07:49 AM
AVID Comes through on my Artist Mix ArKay99 Artist Series 2 02-03-2013 02:52 PM
FS Avid Artist Mix Like New tomhartman Buy & Sell 2 10-27-2012 10:21 AM
FS: Avid Artist Mix jeffinaustin Buy & Sell 1 06-25-2012 09:19 PM
