Error installing required components...PT 11
The next part says "Run the application as the user that installed it and enter the Administrator password if requested."
This is my B rig and 11 stops there every time. Thoughts? Sent from my PT beating heart
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
Re: Error installing required components...PT 11
Are you launching the application as the user that installed it? Does that user have administrator privileges?
Yes. I'm the only admin. That was what was odd. Even ran the admin "enable root user" without success. Very odd. My MPBr is fine! This is a 2011 Spring MBP so that may have something to do with it? 10.3.6 is working fine.
exact same problem here on my Harpertown, running Lion 10.7.5 with 16gb of ram.
I am the only user/admin with no admin password set at all. I tried installing twice. -Chris |
Use Disk Utility (/Macintosh HD/Applications/Utilities/) to Repair Disk Permissions on the Macintosh HD. This might be a case where that process will be helpful.
Repairing permissions and trashing them did nothing. I even tried another install after fixing permissions. no change. The same message comes up.
Thanks, -Chris Last edited by ctyelvis; 06-22-2013 at 07:09 PM. |
Same here Chief Tech! Permission repair was fine.
I think we both know that Harpertown and my MBP were not tested, but I have heard good things about them working with others.
From South Korea... I'm using MBPR with 2.7g and OX 10.8.4. I have the same problem and I'm the only user for this laptop. I had a iLok problem and now with this...
When that error pops up can you move it so you can tell me what the status of pro tools is?? like is it loading plug-ins or initializing anything?
Also as a test if you make another admin user and launch Pro Tools using that account to see if you get the same error. |
Error installing 7.4 ! | jeam25 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-16-2007 12:58 PM |
Email Required Error? Help with the website! | samuelowen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-19-2005 09:53 AM |
Initialization Error - Updated driver required | Larry Younkins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-13-2005 10:25 AM |
Installing 5.1.1 error | deanmartinez | Pro Tools TDM Systems (Mac) | 0 | 01-17-2005 03:41 AM |
error: "A Digisystem INIT is required." | gloriavin | Digidesign Hardware & Software | 1 | 10-10-2003 02:27 PM |
