Old 11-21-2012, 03:03 PM
SmokinBaldMonkey SmokinBaldMonkey is offline
Default BIGTIME EQ Problem in HDX. Or, I may be stupid.
OK, maybe I'm an idiot. All these years, I thought that a high-pass filter on an EQ allowed highs to pass.
I also thought that the degree of slope you assigned determined how sharp a cutoff you would achieve.
So, imagine my surprise when I learned that in this session, the highlighted portion of audio, a snare hit, did not clip the meters until I turned on the HPF.
Once that HPF turns on in PTHD10, the signal level increased an easy 6db.
Get that? No HPF, signal is fine, no clip. HPF on, and the signal clips both the EQ3 output and the track level meter...because the signal is significantly higher....or at least, it is showing me that.
Am I misunderstanding something?
Veni, Vidi, Funki - I came, I saw, I laid the stank down
System 1: Retina MBP 512SSD/16RAM - Thunderbolt HDX1/HDIO
System 2: Mac Mini - 512SSD/8RAM - Thunderbolt HDX1/HDIO
OSX 10.8.5
Pro Tools 10 HD
Pro Tools 11 HD
SYNC HD
Old 11-21-2012, 04:10 PM
Drew Mazurek's Avatar
Default Re: BIGTIME EQ Problem in HDX. Or, I may be stupid.
Deactivate, reactivate. Relaunch PT.
www.drewmazurek.com
Old 11-21-2012, 05:09 PM
BasketCase BasketCase is offline
A high pass filter in the real world isn't just a straight "cut". Part of the byproduct of it is a resonant peak at the cutoff frequency that is proportional to the steepness of the slope. It will actually boost as well. The steeper the high pass... the bigger the resonant peak.
What happens if you reduce the slope from 18dB/OCT to 12dB? Or 6dB? Does the channel still clip?
Old 11-21-2012, 05:32 PM
It does decrease when I change the roll to 12 and then 6db. OK, thank you for that lesson in filters.
But, while we're on the topic, why should that spike occurr in the box? would that not be an artifact of an analog processor? Shouldn't a digital EQ not have such a spike?
Now perhaps Avid should cause the Graphic display to draw whats actually happening instead of leading me to believe that its smoothly cutting away unwanted Frequencies. That was frustrating as hell.
OSX 10.8.5
Pro Tools 10 HD
Pro Tools 11 HD
SYNC HD
Old 11-21-2012, 10:07 PM
blairl blairl is offline
Intersample Peaks
http://duc.avid.com/showpost.php?p=1802757&postcount=54
I have kind of a stupid problem J0hn_Obrien444 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-27-2008 08:23 PM
Help me saulve this stupid problem please gitarrdavid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-11-2008 11:42 AM
Stupid mixdown problem rogga_bogga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-22-2005 06:34 AM
OT: Hey guys need help on a stupid problem :o) gabriel_p 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 10-09-2002 12:03 AM
Vent: Stupid Problem, Why not Fix it? Philthy Pro Tools TDM Systems (Mac) 6 06-01-2001 12:46 AM
