Anyone running HDX + Avid I/O + Lynx Aurora?
REPOST: I originally posted this is in the PT10 forum instead of the HDX forum..
I just traded my HD3 rig for a HDX system + an Avid 16x16 Analog, and a Lynx Aurora 16. I also have a Digi Sync I/O and a 192 I/O. I'm trying to get them to play nicely but having a ton of issues. All the Avid/Digi gear works together no problem. When I had the Lynx to the system, I get constant errors saying the number of peripherals has changed, which requires a full system power down (including interfaces) and multiple reboots to get it working again. Has anyone got this running successfully? How do you have your word-clock cables patched? I have all the latest firmware updates installed for the Lynx but it's giving me no end of grief. SYSTEM: Mac Pro 12-core // OS 10.7.3 Pro Tools HDX // Pro Tools 10.2 Sync I/O Avid 16x16 Analog I/O Digi 192 I/O Lynx Aurora 16 / LT-HD card
Pro Tools HDX // 11.3.1 HD // 2x Avid 16x16 HD I/O // 2x 192 I/O // Avid Artist Mix 2012 Mac Pro 12-core // 64Gb RAM // macOS 10.12.1 SSL 4056G |
Re: Anyone running HDX + Avid I/O + Lynx Aurora?
I have a HDX3 system with 7 HD i/o s and 4 Lynx Aurora 16...
You have to upgrade the firmware to the HDi/o emulating one... http://www.lynxstudio.com/support_faq_result.asp?q=4#D3 I had the problems you mentioned before upgrading to this firmware. Right now all working perfectly, and the 4 auroras are seen like HD i/o's.
Thanks for your reply. As I stated in my original post, the Lynx has the latest firmware installed already.
I'm having this problem as well, seemingly appears at random. 10.7.2 10.3.2 (was happening on all 10 i think). Have latest firmware on lynx, lynx is second interface. Waiting on a new connector cable to see if it is a physical problem. Only other area to research is do you use Logic with HDX as core? Sometimes I've seen this when I exit Logic, closing HDX core driver and open tools, then the number of peripherals thing can appear (but as said not every time)
I relaunch the software a couple of times and it's back so I don't have to power down completely so that's different to yours. |
Every time I loaded a session with a different sample rate, it gives the error message and I would need to restart the computer. It has gone away now that both the Aurora & the LT-HD have the latest firmware. Contact Paul at Lynx, he's really helpful. Forrester |
Thanks Forrester... I have updated both the interface and the LT-HD card.
I received an email from Paul over the weekend with a bunch of info so I'll go through it today and see how it goes.
Anyone been having troubles using H/W Inserts with their Aurora, with regards to Delay compensation, using this new firmware update?
I seem to need to put Time-adjuster plugins on the H/W insert Auxes and delay them by 2 extra samples to get them to "kinda" phase align, as opposed to doing nothing with the old LT-HD firmware. That's at 44.1 & 48khz. At 88.2/96khz it gets really wacky. Forrester Mac Pro 12-core, OS 10.7.3, Pro Tools HDX, Pro Tools 10.3.2, Digi 192 I/O Lynx Aurora 16 / LT-HD card |
Syncing issue with Avid HD I/O & Lynx Aurora | fsavell | Pro Tools HDX & HD Native Systems (Mac) | 16 | 12-27-2015 05:47 PM |
Anyone running HDX + Avid I/O + Lynx Aurora? | ilovemyssl | macOS | 0 | 11-08-2012 09:36 AM |
FS: Lynx Aurora 8 with LT-USB | Jantzen | Buy & Sell | 1 | 06-13-2012 10:58 AM |
PT 9 LE with Lynx Aurora | metro williams | Windows | 2 | 09-07-2011 07:36 AM |
Anyone using a Lynx Aurora 16 with PT9? | deskman | Pro Tools 9 | 9 | 12-10-2010 09:51 PM |
