Old 04-28-2012, 12:19 PM
jon9 jon9 is offline
Default Lost my eleven rack interface w/pt 10.1.2
When I turned on PT today it stopped and said there was an update so I updated to PT10.2.1 and now I don't have an eleven rack interface in protools. How do I fix that? The eleven rack works fine just no gui.
Old 04-28-2012, 03:40 PM
sorcerer27 sorcerer27 is offline
Default Re: Lost my eleven rack interface w/pt 10.1.2
Reinstall the Expansion Pack, then do a repair of disk permissions, and finally reboot the system.
Old 04-28-2012, 06:29 PM
Benoni's Avatar
Benoni Benoni is offline
This is a common "problem" when updating your version of Pro Tools. The reason is because it is the Pro Tools plugin folder that contains the UI plugins for the Eleven Rack, and since 8.0.1 the UI plugins for the Eleven Rack contained in the PT install are the original UI plugins, not the updated plugins that come with the ERXP.
I have written about this issue on my blog site, and there are detailed instructions there on how to re-install the updated UI plugins, as well as links to the ERXP.
http://elevenrackusers.blogspot.com/...howing-in.html
As stated above, you need to re-install the ERXP, but just the first section.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 04-28-2012, 07:50 PM
birdie_in_Texas birdie_in_Texas is offline
What if the expansion pack came already loaded on your 11R like mine?
Same thing?
Desktop PC:
Gigabyte 970A-UD3 | AMD Phenom II X4 965 BE @ 4.2ghz | 16GB G.SKILL Ripjaws DDR3 1600 | Win7 64-bit
Pro Tools 10.01 | Eleven Rack + ERXP
Old 04-28-2012, 08:00 PM
Benoni's Avatar
Same thing?
Yep. Thats precisely why everyone now has access to the ERXP, as I mention in the article I linked to above.
and in this older blog post as well.
http://elevenrackusers.blogspot.com/...even-rack.html
You only run the first section of the ERXP. You won't be able to run the Firmware updater, nor do you need to, because you do not have the needed SN and ID codes that you receive in your avid account when you purchase the ERXP.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Eleven Rack as Interface Dopamine macOS 10 02-02-2013 11:35 PM
Eleven rack with another interface ? oplatner Eleven Rack 11 05-30-2012 07:33 AM
Eleven Rack vs. Eleven Rack to another interface petesteen Eleven Rack 1 02-05-2012 02:53 PM
PT 9.0.5 update lost Eleven rack expansion lbar11 Eleven Rack 6 09-28-2011 09:41 AM
Eleven Rack + Another interface? Kaigne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-01-2009 06:49 PM
